Question about Dell 942 All-In-One InkJet Printer
Dell A940 paper jam switch
I had a bad paper jam awhile back. I had to pull the paper backwards since then I have to reset the paper jam switch. I will print once then show jam. Is it possible I tweaked the jam switch? And does this make sense? I reset the switch then push paper through and here the jam switch trigger.
thanks for any help.
Baja
    Scholar:
  • 155 Answers
Either the gears of the paper feeder are cracked or misallignewd and needs to be replaced or readjusted or the sensor which detects the paper in the tray is broken. so you r facing this error. please check it out. it will solve your problem. this is a common problem faced by many users and get proper . if you dont have any idea of how to check it out.then call a technician he will do it for u.the cost will be negligible.
thanks.
Posted on Oct 26, 2008
My AIO 940 printer does not pull paper properly to print, it does not pull one side of the plain paper and creates a paper jam.
I was having the paper pull to the right. I opened the cover to expose the ink carriages. I found sticky black ink on the platform under the ink. I used a towel and rubbing alcohol to clean off any excess ink. I believe that the sticky ink buildup on the left side did not allow the paper to feed properly. All seems to be well. Hope this helps.
Feb 26, 2011 | Dell A940 All-In-One InkJet Printer
No paper jam evident still says paper jam Dell A940 How do I open it to find out.
go to www.dell.com, FAQs will help, perhaps your anser can be found there ?
do you have the manual for this product ? have you gone to the dell site to get help from tech support
for a manual download,  click here , http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Oct 16, 2010 | Dell A940 All-In-One InkJet Printer
Dell A940 printer will not pull down,or start
I got it fixed........But if I told you how...I would need to charge you $6.95 per month.
Dec 24, 2009 | Dell A940 All-In-One InkJet Printer
HP deskjet 1280 paper jam
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
Sep 11, 2009 | HP DeskJet 1280 InkJet Printer
Paper feeds to the right and Jams
Sounds to me like there is something in the paper chanel, a staple, paper clip or something small enough to get in there. Have you tried turning the printer upside down and lightly tapping the side to see if anything falls out?
Mar 14, 2009 | Dell A940 All-In-One InkJet Printer
A940 doesn't feed paper correctly
My DELL A940 printer used to jam every time with the paper pulling to the right.
Solution - there was a pen jammed in the mechanism !
I was about to trash the printer when I looked deep into the workings from above, holding the printer to the window to get bright sunlight into it. I could see a round ballpen laying in the groove at the bottom.
Hooked the pen out and all is back to normal.
This may not be your problem, but its worth a look.
Dec 26, 2008 | Dell A940 All-In-One InkJet Printer
How do i remove a stack of paper jammed in my printer
refer to manual - all else fails pull backwards canot harm now-
Nov 07, 2008 | Dell A940 All-In-One InkJet Printer
Dell 924 inkjet printer
remove all paper, open cover and see if you can see stuck paper.....never try to pull out backwards...try to pull out in direction of normal paper travel..if you absolutely have to pull out backwards unplug printer first and be gentle as to not break rollers or gear(s)
May 17, 2008 | Dell 924 All-in-One InkJet Printer
A 940 paper feed problem
Dec 28, 2007 | Dell A940 All-In-One InkJet Printer
Dell A940 printer
definately there is paper inside you do one thing remove the toner and see or try to open the drum assemble roller and see is ther any paper inside. bye
Sep 28, 2007 | Dell A940 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
74 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
