Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How do i install without the disc??
Is it possible to install without the cd rom as i have moved and do not no where i have put the disc???
  • kelticgirl Nov 11, 2008
    my computer crashed and I cannot find the disc to reinstall my printer and every solution online does not work in reinstalling my computer
  • trist4240 Nov 15, 2008
    I can't find my disc so now I can't use the printer with my computer at all.
  • 31 Answers
Posted on May 24, 2009
  • 1,901 Answers
You can go to Epson Support and download the driver.
If you need more help, post the model number and operating system you are using.
Posted on Oct 26, 2008
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
Jan 03, 2015 | Acer Computers & Internet
Cd-rom won't engage
Maintenance might be the issue. Open you cd rom Drive. Take a piece of cotton wool or microfiber cloth. Make it damp with vinegar and wipe the small glass eye you see in your cd rom drive. Please be as gentle as possible because that small eye is sensitive. Then try playing your discs
Jan 15, 2014 | Gateway MX8711 Notebook
Is it possible to purchase the installation software cd rom? i also need the cd-rom with acrosoft photo impression kodak 8.5" pidture paper pack and set up booklet ? Items lost during move. How much...
For the Lexmark installation disc, please contact Lexmark Technical Support Center for assistance.
You can also download and install the Lexmark Z25 Printer Driver by visiting the Lexmark website.
Aug 09, 2011 | Lexmark JetPrinter Z25 InkJet Color...
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
Installation problem.. at the end of installation of the game ''desperados'' it is showing error occured during installtion and gives a error number as ''2''.
Error 2 has to do with your cd-rom not reading the disc correctly. Make sure the lens on the cd-rom is clean and it should install without a problem. You'll need a cd-rom cleaning kit for this.
Also if you can try installing the game on another computer. You should also check your CD's surface. Good luck
Apr 12, 2009 | Computers & Internet
Webcam Installation
hi veloriumcpt sure you can download the drivers from the philips website itself.hope u get it through.
May 17, 2008 | Computers & Internet
yah.. borrow some PC with cdrom working.. compy all files from installer cd to USB flash drive.. then install cam to your pc without cd rom.. or you can download installer from internet..
Jan 01, 2008 | Philips J44414
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
103 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
