I was watching TV and it shut off and will not power back on. I have tried unplugging it from the surge protector and plugging it directly into the outlet and I checked the power cord. I called Samsung but unfortunately my model does not qualify for the free repair. Any suggestions?
SOURCE: Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
SOURCE: Plasma TV-power light does not come on
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
SOURCE: It went DARK!
I have the same T.V., we've had it for about 6 months but yours may be the power cord, check the back and move it to places to see if a certain angle turns it on. If not then check the power cord for bare wiring which is the metal hanging out of the rubber insulation.
SOURCE: 50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
SOURCE: Samsung LN52A650 lcd will not turn on after power
open it up / there should be a glass fuse replace it/ull find it were the mains lead goes on the board/also try new lead just incase
