Question about General Electric E850 Digital Camera
How do I use the auto timer in my camera model e850
Ge E850 will not take picture if flash is on. The flash icon will just blink. Will take picture if turn off flash.
If the flash cannot get a full charge, it will blink and prevent a picture from being taken. check your batteries.
Jun 12, 2011 | General Electric E850 Digital Camera
I cannot get my E850 to download pictures. Do not have CD. Where can I get software
There are download drivers available for this camera. Log onto www.opendrivers.com/driver/.../ge-ditigal-camera-e850-firmware-v1.04-free -download.html -. Try it. Make a CD backup once its downloaded. Also be sure you have the right USB cable between camera and computer. Otherwise, take out the SDS storage card and plug that into a $19 usb card reader and you don't have to worry about slow downloads. Some photo editing programs such as PhotoShop and even some freeware may red directly from the camera without any download software.
Mar 12, 2011 | Cameras
Lens error appears on my ge e850 camera lcd screen
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | General Electric E850 Digital Camera
On my GE E850 Camera the view screen just turned black. Still takes pictures but I cannot see them on the screen
Hi I am vortash .. it sounds like the backlight on your screen has gone or the power supply to it , if your camera has an av output try it and see if you are getting a picture from it that way .
If not it may be a video output fault even though your still getting pictures ,as that is a different system . You will need to check the backlight and see if it is geting power , if your not adept at this type of thing i would suggest a repair shop . You may end up doing more damage than good if you don't know what your doing .. regards Vortash
Jun 25, 2009 | General Electric E850 Digital Camera
I have no power, I tried changing batterie with a new one but it still doesn't work
I understood that this model takes special battery pack ...so try to replace the batteries with high quality ones...the regular batteries are not able to power it up ... and by special I mean try something a little more expensive ....I believe its an issue related with the amperage ..anyway ...in case you know for certain the camera is in good condition ....I'm talking by experience cause I also had the same problem with a Panasonic one ...with almost the same tech specifications...and it did powered up after I bought better quality batteries... let me know how it worked up ...have a good day !
May 30, 2009 | General Electric E850 Digital Camera
Need to purchase a battery charger for my ge e850. where can I buy that?
The charger model for your camera is the GB40.
Here is a link of where you can purchase this charger.
http://www.snapitdigital.com/itemdetail.asp?mod=POGB40KIT
Have a nice day ;)
Apr 20, 2009 | General Electric E850 Digital Camera
Displayscreen scratched on ge e850
Most likely you cannot. I recommend calling support. If you have warrenty on the product, they may give you a new screen, but since it's accidental damage, they may not.
Jan 11, 2009 | GE E1030 Digital Camera
MY CAMERA WONT TURN ON AND I GOT A NEW BATTERY ITS A BRAND NEW CAMERA ALMOST HELP
there may be a hold botten on the camera (so the camera does not turn itself on wile moving it and bumping it) look close for a switch!
Dec 09, 2008 | General Electric E850 Digital Camera
General Electric E850 Digital Camera Logo
Top General Cameras Experts
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
