Question about Apple iMac G4 Desktop
My imac g4 powers on but goes to a gray screen with flashing folder what can i do
  • Apple Master
  • 739 Answers
The flashing folder means that the Mac cannot find its start=up folder.
This is caused by one of two things:-1. The hared-disk is going or has gone bad and will need to be replaced. or 2. There is directory damage.
Directory damage can be fixed in several ways.
First of all try starting you computer with the system CD in the slot.
After a few moments with the flasshing ! it will boot from the CD and ask what language you want to use as the computer is thinmking that you are going to reinstall the software.
we aren't.
Go to the next page and then from the menu bar select utilities.One of the utilities is disk utility, szelect that.
After a little while you will get presented with a new window with your HD listed down the left hand side. It will have two entries - one will be Western Digital. Seegate or Fujitsu or so mething sim ilare and the second will be Macintosh HD (or whatever you have renamed it)
If you see nothing - thern the HD is dead. (you have got everything backed up haven't you?). Click on the name of the drive and then c;lick the tab in the centre that says 'First Aid'.
Now at the bottom of the window you will see four buttons, 2 on each side. Go to the one that says 'Repair HD' and then leave the machine for 10 minutes or so.
If the drive has simple directory damage DU will fix it. If ity is complicated damage it will fail with a message.
Try it again as sometimes it has to make more than one attempt. If however, after 3 goes it still fails then you need somethinmg stonger..There is a program we use called Diskwarrior. `Its sole purpose is tyo fix directories.
Sometimes it can take a cople of hour to work, but in the last 10 years I've only had 2 machines where it hasn't been able to fix the damage.
Post back how you get on. Thanks.
Posted on Feb 20, 2012
  • 82 Answers
SOURCE: ? imac g4 ? problem starting
This looks to be a hard drive issue....if you are familiar with the machine enough to take off the bottom plate.....requires a torx tool. I would take off the bottom plate and disconnect the hd, and then see if the machine will boot to cd...if it will then boot to cd then it is a hard drive... i would be careful though as there is a pad on the processor that cools it and if it becomes dislodged you can overheat the processor....
Posted on Mar 10, 2009
  • 50 Answers
SOURCE: when i stert my g4 imac,s screen was became blue
You need to reset your pram
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Posted on Jul 29, 2009
gserle1
  • 4 Answers
SOURCE: imac g4 lcd black screen replaced pram battery
If you can find an older SVGA monitor, try hooking it up to the port on the back of your mac. If you get video then chances are the LCD display is shot.
Posted on Sep 02, 2009
  • 1099 Answers
SOURCE: when my imac g4 tries to bootup it shows a folder icon
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Posted on Oct 13, 2009
  • 1619 Answers
SOURCE: iMac G4 17" Flat Panel 1Ghz, new PSU, boots to Gray
Sounds like possibly the motherboard has thrown in the towel.
1 thing to check is did you apply new thermal paste to the processor before putting motherboard back in?
Did you make sure all wires were seated as you pushed motherboard back in?
Posted on May 15, 2010
I was using my I Book G4 when it stopped responding. I powered down and restarted. When it began restarting it went to a gray screen with a file folder in the middle of the screen. the file folder had a...
Hi ,
take out the battery for 5 minutes , this resets the computer , , if this does'nt work , put in a bootable disk and try to recover the system ...........let me know if this works , i can advise futher
Goodluck Roy
Aug 27, 2011 | Apple PowerBook G4 Mac Notebook
Flashing question mark folder
Use you original startup disk to repair your drive and setup the startup drive for booting. If that doesnt work you may have to reinstall the OS.
May 20, 2010 | Apple iMac G4 Desktop
IMac G4 Mac Desktop: i have a IMac G4 that when i start it a folder wit...
It can not find the hard drive or the startup folder on the hard drive. Try and fix that by putting in the original boot cd/dvd and repair and choose your hard drive start up folde as boot device. If you can not your hard drive may have died.
May 16, 2010 | Apple iMac G4 Desktop
IMac G4 17" Flat Panel 1Ghz, new PSU, boots to Gray
Apr 18, 2010 | Apple iMac G4 Desktop
When you turn the comuter on, it just shows the
--SAFE BOOT MODE--
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X StartupItems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
This should help get your iMac G4 back up
and running.
Regards,
Mactechtrainer
Jan 30, 2010 | Apple iMac G4 Desktop
When my imac g4 tries to bootup it shows a folder icon
Oct 03, 2009 | Apple iMac G4 Desktop
When i stert my g4 imac,s screen was became blue
Jul 01, 2009 | Apple iMac All-in-one - 3.06GHz Intel Core...
Imac g4 dead
Hello, The power supply is part of the motherboard in the iMac G4, so it's hard to change it. The repair would certainly cost more than the price of your iMac. You can try to take off the small battery, and reboot it to see if it changes. To open the mac lay it down, screen on the table (on a t-shirt). Unscrew the four screws (they wont come out, so just unscrew them. Pull the screws and take off the silver plate. Then you'll have access to the inside. Good luck
Jun 12, 2009 | Apple iMac G4 Desktop
Apple iMac G4 Desktop Logo
90 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
