Question about Toshiba Satellite P35-S609: Pentium 4-3.2 GHZ, 512MB RAM, 80GB Hard Drive, DVD-RW/CD-RW, 56K Modem, Network ... (SATELLITEP35S609PENTIUM) PC Notebook
Shutdown Toshiba satellite p/35 s-6091, shuts down while watching streaming video online. Otherwise I can stay online for ever. It has also shut down on me while running my virus scans. No error codes. will start right back up and run with no problems but while I watch my shows online, it shuts down. Black screen and powers off.Sometimes an hour sometimes 10 mins.
  • atcxtroidina Oct 26, 2008
    That software is way above my knowledge level. The only thing that I learned from it is that my cpu got up o about 41c when it shut down. What is safe operation temp? Would a tray with additional fans do the trick, maybe?
    Thank you anyway EIApe. Maybe a more user friendly software, if yoiu know of any.
    Problem Solver:
  • 12 Answers
Problem is with clogged fan ports. Needs to be cleaned by taking apart. Fans can then be cleaned compressed air. You could try a vacuum to **** some of the debris out of the ports but be carefll not to provide too mch suction as it may damage some of the fins. This is a temporary fix as a complete dissassembly must be done. The CPU overheats to to the demands of the video decoding puts on the processor.
Posted on Mar 15, 2009
  • 68 Answers
Hmm, could be an overheating problem.
Do you have any temperature monitoring software on your laptop you could use to check the cpu temperature while watching streaming video?
If not try downloading and installing this.
http://www.almico.com/sfdownload.php
Regards
Nick
Posted on Oct 26, 2008
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
Random Shutdown
Toshiba's are notorious dust collectors, try blowing back through the air vents and some clever use of the vacuum cleaner on the intakes can bring it back to life. also check the RAM for dust and dirt on the pins and clean as required. USE ANTI-STATIC Precautions!
Feb 21, 2009 | Toshiba Satellite P30 P35 Series Notebook
Toshiba satellite that randomly shuts off
may be hitting event of your laptop
also u can try to reset your bios.
go to your bios setting load default settings.
then restart pc.
Apr 01, 2008 | Toshiba Satellite 1805-S274 Notebook
Computers & Internet Logo
188 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
