Question about Hardware & Accessories
How do I push the pins down on Model GE5110N 24 hour timer?
Says to push pins down, how?
  • 4 Answers
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
VtToolMan
  • 704 Answers
SOURCE: timer always turning lights on randomly
Yes, the timer should not require you to reset the pins every 24 hours. Return to place of purchase and let them know it is defective and doesn't work according to the instructions, etc.
If you have no luck in getting a refund, contact the manufacturer directly and let them know you are dissatisfied with this product, but am willing to accept a replacement, etc.
Hope this helps and best regards!
Posted on Aug 21, 2009
SOURCE: GE 24 hour programmable basic timer - how do i
The unit comes with the buttons already pushed down. You have to pop them up.
Posted on Oct 29, 2009
So, this timer came with no instructions. What do you want for $3.99. Made cheap in China and instructions cost more than the timer.
The timer has a dial with tabs all around the 24 hour clock. They are in the down position which is on. You must pull all the tabs up in the times you want the timer off. This is different from all the other timers I have that used that have two removable tabs that are placed at the start and end times.
Put the switch on the side of the timer in the timer position.
Posted on Dec 14, 2009
  • 52 Answers
SOURCE: need timer trippers for model 3405 24 hour
Replacement parts at electricalexpeditors.com
Posted on Dec 30, 2009
How do you use a brinks mechanical timer 42-1020? I have figured out what all parts are just don't understand how to use the pins??
Brinks 42-1020 is analog timer with 48 segments (pins) located around edge of dial.
Each segment (pin) represents 15 minutes in 24 hour day.
Segments on this timer push down and outward.
Open following links for instruction illustrations:
http://waterheatertimer.org/pdf/Brinks-42-1020-manual.pdf
http://waterheatertimer.org/How-to-set-timers.html
Aug 19, 2011 | Hardware & Accessories
I just bought a GE 24 hour mechanical time # 15152. How do set it? The dial is very confusing. I understand that I must first pull all the buttons up and push down the ones I need. If I set it to go...
GE 15152
http://waterheatertimer.org/GE-timers-and-manuals.html#15152
Light side of dial is am hours
Dark side is pm hours
Set timer ON from 5pm to 11 pm:
When segments are down, timer is ON.
Lift all segments, except segments between 5 and 11.
Rotate dial until current time lines up with arrowhead located on inner dial.
Move switch to TIMER ON
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do I set a plug in timer GE 24 hour Model 15075? There are tiny switches for every hour and can be pushed towards the inner circle or pushed outward. And there is a turning arow near the center and a...
Following link has a close-up photo of on-off pins on GE 15075 timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Pins are located around timer dial
The pins divide 24-hour day into 1/2 hour segments
Pins are out for ON
Pins are inward for OFF
Notice that numbered dial is divided into dark and light areas ... the dark areas are PM, light areas AM.
For example you are connecting chicken coop lamp to this timer.
Turn lamp on and make sure bulb is working.
Plug lamp into timer.
Set pins in and out as follows: all pins outward between 4:30 pm on light part of dial to 8:00 pm on dark part of dial. And then set all pins outward between 5:00am on dark part of dial to 7:00 am on light part of dial.
Plug timer into outlet
Move switch located on top to TIMER ON
Manually rotate timer dial clockwise to see lamp turn on and off.
Lastly, set current time: Manually rotate timer dial clockwise until current time lines up with arrowhead located on inner dial. So if current time is high noon, then rotate dial until 'sun' symbol located on light part of dial lines up with arrowhead.
As time passes, the timer dial rotates, and the pins click circuit on-off.
To override timer, move switch to outlet-on.
Jan 09, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Setting the GE timer 15119
the GE timer 15119 is a push pin design. The easiest way to start is to ensure all pins are up, then push down the pins that represent the time period you want the appliance ON. For example, if you want a lamp on from 7pm to 10pm, push down the pins between the 7 and 10 on the black portion of the dial. then rotate the dial clockwise until the arrow points to the current time of day. Turn switch to the "timer on" position. Plug the timer into the wall outlet, then plug the lamp or appliance cord into the timer and you're done.
Hope this helps.
Dec 29, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Where are the pins on the outdoor mechanical timer "woods #59382
The "pins" are the 48 little tabs that are around the clock dial. That would be 2 in every hour of the 24 hour day.
Push down a pin to start the device that you want to control and pull up the pin at the time you want the device to stop.
Dec 21, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Need instructions to set the First Alert TM220 Timer.
For the Model TM-220, 24 hour timer set as follows:
1. Begin with all timer segments on the dial 'pushed up'.
2. Push 'down' the segments required for the 'ON' time;
each segments represents 1 hour.
3. Rotate the dial clockwise until the 'TIME NOW' aligns with the pointer.
Mar 19, 2010 | First Alert 24 Hour Timers - 2 For The...
I have the GE Plug in Mechanical Timer Model 15119. I have the pins pulled up on the white side at 5 and on the black side at 5 and the side setting on the timer position. Yet when I plug it in the wall...
We had the same problem when we first tried to set our timer. Although we have a newer model, this might work for your timer as well. The pin for each 1/2 hour interval that you want the device to be "on" must be pushed toward the perimeter of the dial, not the center of the dial. For each 1/2 hour interval that you want the device off, the pins should be pushed toward the center of the timer. Don't forget to move the arrow on the dial to the current time just before plugging in the timer. Be sure the switch on the side of the timer is moved to "timer on", the override is "outlet on" for when you want your device to come on during the time that the timer is set to have your device turned off.
Dec 27, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
GE 24 hour programmable basic timer - how do i push the keys down. is there a diagram? I tried and tried. The product is the Basic Time.. no pin. #15119
Oct 06, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Timer always turning lights on randomly
Aug 21, 2009 | Hardware & Accessories
Hardware & Accessories Logo
67 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
