Question about Siemens Gigaset 4200 Cordless Expansion Handset
What's your problem?
Screen on handset flashing SEARCHING How do I solve that?
2 Suggested Answers
AKAShadow
  • 32 Answers
SOURCE: Handset flashes "searching" and has stopped working
Did you already try cleaning the connections on the phone and the base with alcohol on a Q-tip? Make sure the connections on the phone are touching the base propely.
Posted on Jul 19, 2007
Why is the handset flashing a "searching" message?
Hi Margaret
This could be that the handset and the base unit aren't synched. Try placing the handset in the base unit for a few seconds and see if that solves your dilemma.
Hope this helps.
-Steve
May 29, 2015 | Lands Phones
Why is the handset flashing "searching" and can't be cleared?
Hi Margaret
This could be as simple as the handset and base unit aren't synched. Try placing the handset in the base unit for a few seconds to see if that solves your problem.
Hope this helps you out.
-Steve
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
My lg cookie kp500 is not working properly the touch screen seems to have frozen ?
To solve your problem you need to FLASH your handset.
And then also your screen doesn't works then you need to
change it.
Thanks
Aug 28, 2011 | LG Cell Phones
Handset display reads "searching". No dial tone. No response.
I am sure you have solved this problem by now. For others who might face the same problem...just unplug the batterry of the handset and plug it in..wow it works!!:))
Jan 20, 2009 | Uniden DECT 6.0 Cordless Telephone...
Second base has searching on it
You too? Mine just started doing this 3 days ago, Nothing on the board looks fried but it doesn't get any signal, I've tried reregisetering the handset but it fails every time.
May 17, 2008 | GE 28112EE2 Cordless Phone
Connection between two phones
There might be two problem....1st of programming and 2nd one of internal hardware problem of your handset which is not working.
For the 1st option- Read manual carefully, there is security setting. Follow the steps with second one handset which is not responding.( I can assum that it is power on but not responding to signals..May i right?) After completing security process it will give long beep and will bond with other one and that is necessary for frequiency adjustment. This generally occures after removal of batteries.
For the 2nd option- There is crystal inside your handset which is resposible for generat stable and similar frequency as other handset. When that crystal lost its capacity it results in mismatching of frequency and occures in non connection results in no response from handset. This can be repaired by technician after getting part no of that crytal from your device and replace it with another one. But for this you have to visit technician with all of handsets and attachment as it is necessary to check it working properly after repair, even technician may also need it for setting frequency level.
Is it clears all doubt about this problem then say FIXYA......
Jan 09, 2008 | Siemens Gigaset 8800 Cordless Expansion...
Jul 19, 2007 | Siemens Gigaset 4210 Cordless Phone
Siemens Gigaset 4200 Cordless Expansion Handset Logo
19 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
