Question about Kenmore 98702 Stacked Washer/Dryer
Can't separate washer from dryer to fix leaky hose
My washing machine is leaking clear water during both fill cycles. We can see that the problem is a hose but in order to replace the hose we need to get the dryer off the top fo the washer. We can get one side disconnected but see no way to disconnect the other side. Any suggestions?? Thank you!
  • Anonymous Mar 30, 2014
    leak in top inside of washer in the area of where the hoses connect on outside of machine
    President:
  • 878 Answers
Sesler, Does your model number beging with 110? If it does you should not have to remove the dryer, taking a puddy knife and pushing on the clips on the left and right side of the washer top should release the front panel. Here you should be able to access any hoses and the top should lift. If your washer does not begin with 110 disregard this post...Catriver..post back.
Posted on Aug 24, 2006
I have a WF448AAP/XAA washer and is leaking from the bottom, what it be?
Could be the bottom seal of the drum, a leaky hose or the pump that discharges the water out of the drum during rinse cycle. If it seems to leak while filling and/ or operating my bet would be the drum seal.
Nov 27, 2014 | Washing Machines
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Supra SW5L65D Front Load Washer / Dryer
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
Jun 28, 2010 | Whirlpool LTE6234D Top Load Stacked...
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Kenmore 98702 Stacked Washer/Dryer Logo
541 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
