Question about Whirlpool Dryers
Whirlpool model LET6638AWO serial MC5103712 won't heat up
maddogsteve1
  • 18 Answers
SOURCE: Kenmore dryer model 86870800 won't heat
thermal fuse is behind blower housing on models w/lint screen in door and on the back of the dryer on lint screen on top models.
Posted on May 24, 2009
protek480
  • 1714 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 12, 2009
ned_san_jose
  • 234 Answers
SOURCE: Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Posted on Sep 15, 2009
aasc
  • 1606 Answers
SOURCE: MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Posted on Aug 02, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have an electric whirlpool
Hi dustin me413...
Try some of these tests to locate your problem
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 27, 2011
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
Heat and Glo pilot light works but Burner won't go on. I messed with it and it started up but won't turn off. next day won't start but the pilot light is still on
light your pilot and take a light to the termopile (right beside your pilot it sticks out to get heat from your pilot. hold lighter for 5 seconds and turn gas on
Dec 08, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Why won't the dryer heat
the heater element and/or the stats may need replacing
cheap on ebay.........
cheers
Jul 28, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Won't start
sounds like you have a bad motor,when it heats up it stops running and when it cools down it will run again but one of these times it won't run anymore until you change out the motor.when the motor gets hot you might smell a shellac smell,this is the windings on the motor heating up.part number 8528157 and it's around 120 dollars on the sears site
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-LSQ9549LW3/1198/0153200/W0312163/00005?blt=06&prst=&shdMod=watch this video to change motor
http://www.youtube.com/user/RepairClinic?v=Oeiyjt7807o&feature=pyv&ad=5457341981&kw=washing%20machine%20motor
May 07, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I took the wires off my whirlpool cabrio dryer heating element &I don't know where they go
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
Apr 19, 2012 | Dryers
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Dryers Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
