Question about Viper Vehicle Parts & Accessories
Blue light on the windshield part won't stop flashing when purchased vehicle it was already installed didn't come with any information
Daughter messed with buttons and it was just blue no flashing now it's blue flashing and my hatch unlock, door unlock and lock buttons never worked. Also there is a button on the side of the remote don't know what it's for
  • 13 Answers
SOURCE: driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
Posted on Dec 04, 2008
  • 12 Answers
SOURCE: Remote start not working after installation
this could be a lot of different things.... email me at face2face11@bellsouth.net, and i'll give you my ph# and talk you through it if you want. im an MECP First Class Certified installer with over 10 years of experience, by the way.
Posted on Jan 22, 2009
  • 309 Answers
SOURCE: I have an astra remote
Check the battery in your remote first. Then check all fuses for the Astra. Sounds like the main one at the battery.
Posted on Jan 24, 2011
logosc75
  • 625 Answers
SOURCE: just notice blue lights flashing
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Posted on Feb 11, 2011
Testimonial: "Thanks for clarifying the reason why. The system is brand new to me. Was not aware of that feature. Thanks again."
xxCARxx
  • 76 Answers
SOURCE: The door lock/unlock on my
you need to check the battery in the key fob remote . If the battery are good . the remote will need to be tested to make sure it is capable of transmitting (only place i know that can test them is the dealer ship but you could call your local parts store to see if they can test). If the the remote test good then it will have to be reprogramed or relearn to the truck .I belive if it needs to be relearned or programed you will need to have that done at a shop with a proper scan tool .
Posted on Mar 06, 2011
Lights won't stop flashing
to me it sounds like the vehicle may have a security sytem on it that may have a problem
Feb 29, 2012 | 2000 Dodge Caravan
My dad jumped his work truck with my 99ford escort zk2 and I think that he hook the pos to the neg. Well all the bulbs blew and the windshield wipers run non stop when fuse is in. Have everything fixed...
check all the fuses with a meter , not just by sight, then, look under the hood for the fuse block there, check those fuses also, especially the main fuses, 30 amp and above,, with any luck he didn't blow out your computer
Aug 08, 2011 | Ford Escort Cars & Trucks
I have a 2006 Equinox and the transaction light comes on and the gear shift light goes out and it has trouble getting going but once I'm at 30mph it's fine. It only happening when it rains and I...
Sounds like water is leaking in the electrial componets inside the dash panel from the windshield. You should ask the Shop that did the work for thier insurance company infomation and file a claim. The corrosion caused by the water WILL cause further problems in the future. I would have the vehicle looked at by a GM dealer to make sure it's repaired right.
If the Shop won't give you the insurance infomation, contact you State's comsurmer advocate.
Jun 24, 2011 | Chevrolet Equinox Cars & Trucks
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Good luck from Headsets Direct!
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
I just got an oil change in my 2003 vw jetta. The next day my oil light started flashing and beeping and won't stop. Should I be worried??
yes- check your oil level - sounds like they didn't fill completely or something is loose and leaking oil out
May 24, 2011 | 2003 Volkswagen Jetta TDI
Vehicle Parts & Accessories Logo
120 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
