HD writer 2.5E
I have installed HD writer onto my new pc - Packard Bel imedia 2145 with INtel Quad , Vista Home Premium. Unfortunately the programme has not recognised my internal DV burner (Opticare DVR RW AD-7200S ATA ) .This is to use Panasonic HDC-HS9 . Didn't have a problem working on my last pc - windows XP . Really annoying as part of reason buying new pc was to use HD video!
Is it a Vista problem?
Thanks
Andrew
  • Anonymous Dec 14, 2008
    I had Intel Dell Dimension Intel Pentium 1.7MHz Windows XP. Upgraded to Dell Inspiron Intel Core 2 Quad 2.4MHz Windows Vista Home Premium. Installed HD Writer 2.5E and the sound stopped working!
  • Anonymous Apr 12, 2009
    I have a Dell Studio core2 duo - HD Witer 2.5 doesn't recognise my drive
tom19511
  • 1601 Answers
SOURCE: Adding second drive to system
did you change jumper on the old drive to slave? Also check BIOS and see if has it listed.
Posted on Dec 29, 2007
  • 13433 Answers
SOURCE: Pioneer DVR-K17RS ATA ACER CODE=39
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
Posted on Feb 11, 2008
  • 44 Answers
SOURCE: Dead Driver for Easy CD Creator
Resolution WARNING: THIS PROCEDURE MIGHT CAUSE ANY OTHER ROXIO OR ADAPTEC SOFTWARE INSTALLED ON THE PC TO BECOME INOPERABLE. PLEASE UNINSTALL ANY OTHER ROXIO OR ADAPTEC SOFTWARE FIRST BEFORE ATTEMPTING THE LISTED PROCEDURE.
  1. Renaming the Take Two system file
    • Click on the Start button, and then select Search
    • Search your Local Hard Disks for the following file prtseqrd.sys
    • If you do not find this file, please go to step 2
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. prtseqrd.sys would be renamed to prtseqrd.rox)
      NOTE: If you decided to not finish this article at any point please rename this file back, you will be doing that later in this article. right hand corner of the window
  2. Remove Easy CD Creator 5 from Add/Remove Programs
    • Click on the Start button, then go to Setting and select the Control Panel
    • Double click on the Add/Remove Programs icon
    • Uninstall Adaptec Easy CD Creator 5, if prompted choose No to reboot the PC
    • Then click the X in the top right hand corner of the Window to close the control panel
  3. Removing Directories from your Hard Drive
    NOTE: All directories stated might not be found
    • Click on the Start button, then right click on the My Computer icon and then select Open
    • Double click on the icon for the Local Disk that the software was installed to
    • Double click on the Program Files folder
    • Locate the Roxio and Adaptec folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common Files folder, locate the Roxio Shared and Adaptec Shared folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common File\\InstallShield folder, locate the Engine and Iscript folders and rename them to Engine.ROX and Iscript.ROX. Once all the directories are remove right click on the "X" in the top right hand corner of the window to close it
  4. Rename additional files on your hard drive
    NOTE: All files in the list might not be found
    • Search your Local Hard Disks for the following files:
      *CDR4_2k.sys
      *CDR4_XP.sys
      *Cdr4dll.dll
      *Cdr4vsd.sys
      *Cdr4vsd.vxd
      *Cdral.dll
      *CDRALw2k.sys
      *Cdrtc.dll
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. cdrtc.dll would be renamed to cdrtc.rox)
    • After all files are searched for and renamed close the search window by clicking on the "X" in the top right hand corner of the window
    WARNING: THE NEXT STEPS INVOLVES EDITING YOUR SYSTEM REGISTRY. WE STRONGLY RECOMMEND YOU EXPORT YOUR REGISTRY BEFORE SYSTEM DAMAGE. WE RECOMMEND THAT IF YOU DO NOT FEEL COMFORTABLE EDITING YOUR REGISTRY THAT YOU SKIP THESE STEPS.
  5. To export a copy of your registry, please do the following:
    • Click on the Start button, then select Run
    • Type regedit and click the OK button
    • Locate and left click FILE in the upper left hand corner of the Registry Editor, then click on Export
    • Choose the Desktop as the location to save the file in, and name the file regbackup
    • Also ensure that under the Export Range section there is a dot beside All
    • Click on the Save button. Your registry should now be backed up to a file named regbackup.reg on your desktop.
  6. Remove the Roxio and Adaptec registry entries
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the + next to it.)
    • Expand the SOFTWARE Key
    • Locate the Roxio and Adaptec folders, right click each folder and click on Delete
    • If prompted to confirm the delete click the Yes button
    • Collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Expand the HKEY_CURRENT_USER key
    • Expand the SOFTWARE key
    • Locate the Roxio and Adaptec folders, right click on each folder and click on Delete
  7. Remove the UpperFilters and LowerFilters values:
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the "+" next to it.)
    • Expand the SYSTEM Key
    • Expand the CurrentControlSet Key
    • Expand the Control Key
    • Expand the Class Key
    • Please look for a key containing the following string of letter and numbers: {4D36E965-E325-11CE-BFC1-08002BE10318}
    • High light this key by left clicking once on it
    • On the right hand side you are looking for UpperFilters and LowerFilters under the Name column, once you find these please delete them by right clicking on them and choosing delete
      Note: It will be easier to use the Registry editor in the future if you collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Please exit the registry by clicking on the "X"in the top right hand corner of the screen
  8. Renaming the Take Two system file
    • Search your Local Hard Disks for the following file prtseqrd.rox
    • If found, right click on the file and then click on rename. Change the file extension to SYS (i.e. prtseqrd.rox would be renamed to prtseqrd.sys)
  9. Shut down and Reboot the PC
    • Click on the Start button, then click on Shut Down
    • Choose the Restart option and click the OK button
    • Adaptec Easy CD Creator 5 should now be removed from your PC
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Posted on Mar 28, 2008
  • 5 Answers
SOURCE: How to install XP on pre loaded Vista in HP Laptop
I bought a cheap Compaq laptop that came with Vista Home Premium. The speed was horrendous! Anyway, I received the same no hard drive found error. To solve the problem, I went into the system config (BIOS) by pressing F10 on startup, and turned off SATA hard drive support (its supposed to make the hard drive run faster), I rebooted, inserted my Win XP Pro disc and viola, it detected the hard drive. I would say that the laptop runs a good 40% faster than before. Vista is a big no no when it comes to low end laptops built for word processing and internet browsing.
Posted on Mar 29, 2008
hardkiss69
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Nov 16, 2008
Adjust contrast
That is because there isn't one. All you have is brightness.
Jan 10, 2014 | HEWLETT-PACKARD HP Pavilion dv63236nr...
When I insert disc"WORKS SUITE 2006" nothing happens???
Check disc on other computer/ laptop.
if same result then disc is damage.
otherwise open your dvd Clean the dvd lens by Lens cleaner liquid with carefully avoid scratches over lens.
Sep 26, 2013 | HEWLETT-PACKARD HP Notebook DV6T Select...
How to insert an sd card on a packard bell windows vista home premium computer
Windows logo button ('Start') > Computer > Removable devices.
DOUBLE-click on the file name to the right of - Removable devices
Regards,
joecoolvette
Mar 21, 2013 | Packard Bell Computers & Internet
I up-graded to a Dell Studio Mini-Tower, Intel
This software has some compatibility issues with your operating system. win2000 is the recommended one...
Aug 06, 2009 | Adobe PageMaker Plus 6.5 for PC
Computer saying high definition audio device working as does the
click on START-SETTINGS-CONTROL PANEL- DOUBLE CLICK "SYSTEM"- SELECT THE "HARDWARE" TAB AT THE TOP- CLICK THE DEVICE MANAGER BUTTON-
NOTE: Any entries found here with a YELLOW ! OR ? are drivers the are corrupt, wrong or installed incorrectly. They will need to be uninstalled and new updated drivers downloaded from the internet installed in thier place.
Regards..
Apr 06, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Boot problem
yes i would try to upgrade bios and firmware in all if any has one update thats alot poweer u need hope u have least 600 w dual rail
Jan 19, 2008 | Abit IN9 32X-MAX Motherboard
Computers & Internet Logo
522 people viewed this question
David Payne
David Payne
