Question about Acer Aspire 5500 5570-2609 Laptop
Aspire5570z power hookup
Where cord plugs into laptop is loose and sometimes accepts power and sometimes dont, is loose
  • 68 Answers
Wolflover,
I have seen this on numerous laptops, basicaly the DC socket is either physically broken or has come adrift from the mother board.
Its a relatively simple fix if you're hand with a soldering iron or if not its a 30 minute job for some one who is, 20 minutes for dismantling and re-assembling the laptop :)
Please let me know if you need any further help
Regards
Nick
Posted on Oct 26, 2008
Hi my acer desktop sometimes refuses to switch on and other times it switches on. When it accepts to starts, it sometimes switches itself off when am working. What could be the problem?
Could be a combination of things causing this, "What to Check Out" first off it may be the power button it may be worn and in need of replacement. Second could be a short in the power pin input where you plug the laptop in at. Plug it in when working or not working and wiggle it around gently to see if it lights up or sometime shows a blinking light. If this happens then you will need to have that piece on the board replaced or soldered. Check for shorts in the wires itself see if there are bent wires or crimped up wires on the power cord. Animals are notorious for doing that sort of damage to power cords.
So we know it is a power issue working and not working that is where I would start at. The sources as I explained above. Right now it is something that is shorting out. I believe without seeing the computer itself that the plug in power sources are the issue here. Especially the input plastic pin where you plug the power cord into is a common issue on laptops because they get bent or stepped on or pulled and twisted when using a laptop.
This is why it is critical to be gently with these types of components. Keep animals away from chewing on them as well or when plugging laptops in to make sure the cords are not bent up or twisted but straight inline with the power source plug in on the laptop. This can happen over time as well.
I think that is your issue. While laptop is being repaired if you do it yourself which I do not recommend if you have never done this sort of thing take it in for repairs. Make sure they clean the dust out of the fan and CPU areas as well. John
Apr 17, 2012 | Computers & Internet
Presario laptop issue with power indicator light and detecting powers supply
Sounds like your DC Power Jack is bad or broken. The DC Power Jack is where the power cord plugs into the laptop? Most times it get damaged by too much stress on it such as sitting in bed with the laptop, or putting the laptop in the laptop bag with the power cord still plugged in.
Take an ink pen and put it into where the Power Cord normally plugs into the laptop. If the pin inside the DC Jack is loose or wiggles then the jack is probably bad. Sometimes the jack can be completely burned out and you can smell smoke .
If the internal DC Power Jack is loose, you will have totake the laptop apart to repair it. The DC Power Jack is on themotherboard and most times it is soldered to the motherboard. That meansyou will have to desolder the old one and solder a new one in it's place. Sometimes the dc power jack sits in a slot between the bottom case and palmrestwhich hold it in place and has a cable harness that plugs into the motherboard.
Apr 05, 2012 | Computers & Internet
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
I have an Acer Aspire 5251-1513. I'm not sure, but I think that the fan isn't working. It usually makes some noise, not enough to be bothersome, but enough that I know it's running...yeah. it hasn't been...
Common fault is the little socket where you plug the power supply into goes intermittent, annoying, works sometimes then stops. It's likely you need to get that repaired, the laptop will work with a poor battery but not a poor power lead..
before you go down this road just make sure the little plug on the power lead is not broken inside due to being pulled in and out of the socket thousands of times. Try it on another laptop..!
good luck !
Mar 30, 2017 | Acer Computers & Internet
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
Download land driver for aspire5570z
here's where you can download the drivers for Acer Aspire5570z
http://www.notebook-driver.com/acer/acer-aspire-5570-notebook-windows-xp-drivers-and-utility/
Feb 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
Power port for gateway MT6840
First easy check is to stick a toothpick into the jack to see if the middle pin is loose. If it's not loose, try another power adapter to check just incase. If you dont have one ask around to borrow a universal one. Dont jiggle and wiggle the plug with the power plugged in if it is loose because i've seen shorts happen.
usually plugs are mounted onto the mainboard. To get to the main board, you'd have to take apart everything because everything attatches to the main board. The case, keyboard, heatsinks, speakers, and so on must come off before you'll be able to see the power jack. With parts and labor, it comes close to a new laptop.
Jul 29, 2009 | Gateway MT6840 Notebook
WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Jul 04, 2009 | Western Digital My Book Essential Edition...
Intermittent power connection
I am guessing this is a laptop.
If so, the DC jack on the laptop is bad. The connection between the jack and the motherboard gets loose, or the center pin gets loose. The only fix for this is a jack replacement. It takes soldering skills. You can get it repaired for $100-200 bucks, depending on the shop.
If you have soldering and electronic skills you can do it yourself, but it is tricky if you have never done it.
The only other option is possibly the power cord is bad at the end, where there might be a bend. Sometimes both the power cord and Jack are bad.
Apr 05, 2009 | Computers & Internet
Evo n600c notebook
Hi, your problem is the DC socket Plug on the motherboard. This is a solution 5$ (for the plug only) and soldering iron and solder. If it is within warranty give it straight away for repair at their cost. THIS IS a VERY common problem to HP laptops. Dont Accept anything other than a full repair. (requires dissasembly of the plastics to expose the connector and be able to resolder it.)
If it is out of warranty then find the plug, and DIY or engineer friends may be in order :) If you send it to 3rd partie tech shops they may charge 100-150$ for a 5$ spare part..the rest is their time spent and many six packs.
Regards
Mar 19, 2008 | HP Compaq Evo Notebook N600c
Acer Aspire 5500 5570-2609 Laptop Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
