Question about Microwave Ovens
How do you access internal fuse on 2003 Sharp R1500 microwave?
Do not know how to access internal fuse to check/change. Nor how to change either control or display panel. Does microwave have to be taken down to access any or all of these parts, please?
  • Anthony Barreto-Neto Feb 21, 2012
    Yes it's completely dead, no lights, no sound no nothing as if power isn't even reaching microwave at all. If it weren't one that's goes with stove & very good one I'd consider buying new, but be hard to find match with stove for reasonable price.
    Really needed to know if I have to take it down to get to fuse and it seems I do if located where or near where power cord comes in.
tiway1
  • 100 Answers
SOURCE: Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Posted on Sep 06, 2008
tzweeb
  • 318 Answers
SOURCE: Change Fuse Whirlpool Gold GH7155XHS1
no the control does not come off from behind.
what you will find is the top vent grill has to come off first. it has 2 phillips screws that hold it to the top of your unit.
you will find 4 screws on the top, go ahead and take all 4 out and then pull the grill out from the top and hinge outward to remove/ once the grill is off, then there is 1 more phillips screw that holds the control board/ touch panel to the frame. remove and then lift up then out on the panel.
now that you are into the unit, make sure you have UNPLUGGED it first. the fuse is about 1 1/4 inch long white ceramic material with metal ends. you can find a new one at a radio shack or get one online for your unit. r/s has them for cheap and if that allows the unit to run again, great, but...
there was something that caused the fuse to go bad. so dont be surprised if you need a diode or capacitor to fix why the fuse went bad.
Posted on Feb 03, 2009
  • 686 Answers
SOURCE: fuse blowing on the sharp microwave r-1874
your fuse will be located somewhere close to where the power cord comes in. It's not a regular glass fuse it looks like ceramic with the silver looking ends that's your fuse
Posted on Feb 20, 2009
  • 38 Answers
SOURCE: Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
Posted on Mar 15, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: My sharp carousel II microwave doesn't seem to
Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad?
We have the relevant service / repair manuals for this model and have uploaded it to our site here and here to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open these documents automatically, but you may need the free Adobe Reader
I would suspect the 20A ceramic line fuse or the magnetron temperature fuse.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
20A ceramic fuses are available at local appliance part stores or places like Wal-Mart and Lowe's.
Posted on Jun 04, 2009
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
No Power
hi,
Did you try replacin the fuse.It might have blown.
Jul 03, 2008 | Sharp R-930AK Convection/Microwave Oven
Start button does not work
If this is a Sharp R1500-series microwave (you didn't mention the model number but posted under that) then the most likely problems are:
- broken Start button see here
- bad door switch see here
- bad keypad or other problem see here
The service manual is here.
Mar 06, 2011 | Sharp R-1510 Microwave Oven
I have the Sharp R-1440 carousel microwave oven and it won't shut off when I close the door. Do you know how old this oven might be? Model R-1440; Serial 123662
Check and change door interlock switches or check for condensation problem on control panel, (internal).
Hope that helps.
Feb 02, 2011 | Sharp R-1480 Microwave Oven
No power not even a clock i hve checked outlets
Well, there is a fuse in these units which sounds like your problem in this instance. You can get to it by removing the outer panel on the microwave. To do this, look for all screws/bolts on the back/bottom of the microwave and remove them. This will let you remove the outer panel and give you access to the internals. Make sure you unplug the microwave first before opening it and don't touch internal components for at least an hour after unplugging it to stay safe. The fuse can be replaced at a hardware or electronics store. Let me know if you need any more help with this.
Benjamin
Nov 03, 2010 | Sharp R-820B Convection/Microwave Oven
Sharp R1500 microwave does not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Feb 08, 2010 | Sharp R-1500 Microwave Oven
Sharp R-150 microwave made a buzz sound and shut off, no power to microwave
When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. Also usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Feb 07, 2010 | Sharp Microwave Ovens
Sharp microwave suddenly died !
The high voltage transformer that feed the klystron tube usually has a cartridge fuse on its 110 v side.
YOu will have to remove the case to access the electronics... the screw should be obvious...
Note.. you are handy- so the obvious (unplug first) and the even more obvious - keep fingers and metal away from all capacitors in the power supply area.
Oct 22, 2009 | Microwave Ovens
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
