Question about Mitsubishi Diamond Pro 91TXM 21" CRT Monitor
Mitsubishi diamond pro 917xm
The monitor has developed "ghost images" to the right of all images, words and lines, which make it difficult when using a CAD program for many hours. I have tried degaussing with out a positive result.
2 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Posted on Mar 02, 2009
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
I want download driver for Mitsubishi Diamond Pro87TXM monitor.
After a google search i found these drivers, http://www.nodevice.com/driver/company/Mitsubishi/page2.html
Hope it helps
Steven Cumming
Please leave positive feedback :-)
Jun 05, 2011 | Mitsubishi Diamond Pro 87TXM 17" CRT...
My screen develops some ghost images after powered up for a few hours. I can actually see some words that appear almost burnt into a screen. Similar to a monitor that has been left on too long if someone...
well you are correct and when it come's with the lcd monitors it is known that when a pixel is subjected to same amount of charge for a long time it might retain the residue of charge even after the amount is changed so this reason why you get this problem and in order tackle this just try to use some changing screen savers or just turn the monitor switch off while you are not around it.
good luck.
Jan 06, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Mitsubishi NEC Diamond PRO 930SB Monitor - cover removal?
Remove the screws as you have done. Looking at the monitor front on you'll see 3 bits sticking down from the top (in the deatil gap) which are clips unclip them by pushing through the corresponding holes along the top. Also there's a clip at each side on the underside of the monitor which are very obvious. With the monitor facing down and everything unclipped just pull the cover upwards. It's not easy but work your way round the front edge and it will come.
Jun 26, 2009 | NEC Mitsubishi Diamond Pro 930SB 19" CRT...
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Ghosting of picture on Mitsubishi Model C28D7L TV
you could try and use the deguas button to see if that helps at all if not then as you mention there is something wrong with the tube as for a new monitor most likely a computer shop - use google maps to find out nearest computer shop.
short of that you may be able to find one on ebay if you trust it http://www.ebay.co.za/
Apr 10, 2009 | Televison & Video
Mitsubishi diamond pro says "no signal"?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Blue Ghosting Help Needed
Good Day, jhazelwd;
From what you say it sounds like the Convergence IC's have failed. Part number 267P150010, STK392-570, replace both IC's. They are on the middle board secured to a large heat sink.
Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Open Questions:
How to select best payroll software in India, Dubai, UAE, Qatar, Oman Using a Payroll Software in Dubai or a Payroll Management Software in UAE will definitely save you time and money. This will allow you to focus on your business. You don't have to be a Payroll Processing expert to use the software. You will need to buy an end-to-end system incorporating your company requirements. Following are the eight components that are going to help you discover how you can choose the best payroll solution. Offline or Online Payroll: You can choose from two types of payroll software - offline or online software. Choosing one solely depends on your business type, your working mode, and preference. Offline payroll is installed locally on your computer. You won't need an internet connection to access your payroll data. With offline payroll, you will have a flat purchase price, and only pay for future upgrades. If your PC/laptop is destroyed, you will not be able to access your Payroll Processing, Payroll Hold, Pay slip, Trail Payroll, Payroll Reports data. Online payroll, also called as cloud-based payroll software, help you to access it anywhere and anytime. You just need an internet connection and your login credentials. This type if HRMS Software in Dubai, UAE, and/or Abudhabi is advantageous if you are always travelling. With cloud-based payroll software, you get to retrieve your data from many devices. You can log in on a computer or on your mobile/tablet. Initial/Recurring Costs: How much do payroll software cost in Dubai, UAE, and/or Abudhabi? As a business proprietor or company's management, you most probably are not looking to spend money to buy whatever is promoted to you. You are looking for affordable services which get the tasks completed. When determining on the HRMS Software in Dubai, UAE, and/or Abudhabi, the cost is one of the main factors. The Business Software Provider in Dubai, UAE, and/or Abudhabi should not charge you hidden costs/fees. You might have overlooked them during the initial HR Payroll Software cost examination. You don't want to quickly select a Payroll Solutions provider and later notice extra costs you didn't know of. There are different pricing models. Always read the contract and understand the full extent of what is included. Add-ons or Modules: Cost is an important factor, but you want the Payroll Management Software to perform to your requirements. Every business is different. The Best Payroll System for Dubai, UAE, and/or Abudhabi should be able to incorporate your business requirements. The Best HRMS Software in UAE should not be different from the Best Payroll Software for Dubai. Service and Support: When using a payroll system, you have got to have control over it. You need to feel comfortable when you get questions. A payroll system should have effective support to help its users. Most payroll solutions have customer support consultants. Most payroll software vendors help in setting up your system. Support is the second most important item in your checklist, compare support provide by different vendors. Your Payroll Management Software vendor should provide phone and/or online support. Learning Curve: Choosing a payroll solution that is easy to understand and use is the third most important thing while selecting a payroll system. Many payroll solutions need some level of prior working knowledge to use them. Take a trial so that you are able learn to use the payroll solution before buying it. Purchasing the Best HRMS Software involves a low learning curve; this results in money and time savings. Trial Period: Most payroll solutions in Dubai, UAE, and/or Abudhabi have trial periods to let the user get a feel of the software. A trial period allows you to gauge precisely what you are buying. Check the payroll solution you are contemplating to see if it has a trial period or not. This lets you determine whether the Payroll Management Software is the right one for you. Security: Security is the third major factor when selecting a HR Payroll Software in Dubai, UAE, and/or Abudhabi. You do not want someone to gain unauthorized access to your employees' personal data? It is a nightmare for management and workers. Always ask how the Payroll vendor secures the data. Any payroll solution you choose should have high-grade encryption, as is bank software. Contract: Ascertain if the Payroll Solution has a contract or not. Payroll solutions don't necessarily have one. Before selecting a HR Payroll Solution, check if there is one. Before entering into one, make sure the HRMS Software fits all your requirements. Sometimes there might be an early termination cost. You should choose payroll software that has no contract. You will be able to cancel the vendor and select another one when needed. You need to make sure that the Payroll Software has Payroll Processing, Payroll Hold, Payslip, Trail Payroll, Payroll Reports function in it. Select the best Business Software Provider in Dubai, UAE, and/or Abudhabi, and that they provide Employee Attendance and Leave Tracking as a built-in function. You should also make sure that Payroll Solutions Portal works in Dubai, UAE, and/or Abudhabi. The above points are the positives and negatives when choosing a Payroll Management Software in Dubai, UAE, and/or Abudhabi. Always make sure it fits your requirements.
Jan 16, 2019 | Major Computers & Internet
See all Mitsubishi Diamond Pro 91TXM 21" CRT Monitor Questions
Mitsubishi Diamond Pro 91TXM 21" CRT Monitor Logo
29 people viewed this question
Top Mitsubishi Computers & Internet Experts
Alun Cox
Argospete
Argospete
john h
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
