I Need pinout configuration on dell E93839 GA0402 motherboard.
Just acquired this Dell E93839 GA0402 Motherboard and cannot find Front Panel Pin-out Diagram for it. Does any one know the pin out or where I can find diagram. Thanks
map9966
  • 2351 Answers
SOURCE: PC Chips M955G Motherboard Front Panel Pinout
Download your manual from this site. Everything you'll need is there.
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?DetailID=302&MenuID=22&LanID=0
Enjoy!
please vote...
Posted on Feb 16, 2008
kigwa2008
  • 68 Answers
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Posted on Jul 25, 2008
  • 56 Answers
SOURCE: Connection Diagram for MSI N1996 motherboard
GOTO MANICATURE WEB SITE TECHN SUPPORT MOTHERBOARD LAYOUT DIAGRAMS
TRY MOTHERBOARD.ORG
IM PRETTY SURE THAT MSI DOES HAVE A WEB SITE ON THE INTERNET
CANDYMANGANDY
Posted on Jan 27, 2009
  • 1602 Answers
SOURCE: Motherboard Pinout - Please Help
here are some sites that may help you.
all these should be marked power switch may say pw,prs,ps, power led may say pld, pl,led, hhd say hd, reset switch maysay rs, set, these connection will be grouped together, and pin layout 1 red or hot wire, or the main wire for the device you are trying to operate.
www.motherboards.org
www.tomshardware.com
www.twinight.org/chipdir/
www.anandtech.com
the connections to the back plate is standard the amount of pins match up the cable, the number 1 pin will be marked some how and or the cable will only be able to plug in one way.
with an exception if you are using serial connector and we hardly use them. the rules are the same as above, and plug ins maybe one way also.
the ribbon type will have a marking on the cable or ribbin line or dots or hasshs marks that is pin #1
match with pin out on motherboard pin1 or pin 0,
rod
Posted on Feb 11, 2009
Hp e93839
~Somewhere, over the rainbow~
My understanding by a search on the internet, is that the HP XW4600, uses a version of an Intel X38 motherboard, and has the ID numbers - model fmb-0702 - on it, as well as - e93839 -
http://h30499.www3.hp.com/t5/Workstations-z-series-xw-series/XW4600-Motherboard-Control-Panel-Schematic/td-p/1007169
7th post down, - jondvd - 09-28-2008
http://www.ebay.com/itm/HP-XW4600-Motherboard-441449-001-441418-001-/360653087990?pt=Motherboards&hash=item53f89964f6
If this holds to be true, the BLUE header, below the CMOS battery, and close to the outside edge of the motherboard, is ONE USB header.
Indicates Internal.
The Yellow header to the right of it, is the Front Panel USB header.
EACH USB header has contact pins on it, for TWO USB ports.
Does not matter which USB header we are talking about here, on that motherboard.
To identify the pinout, look for the missing pin in the header.
This is the KEY pin.
http://www.motherboardpoint.com/front-usb-pinout-compaq-evo-d310-t153627.html
http://pinouts.ws/usb-pinout.html
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
Front panel usb and controls for dell 2350 dimention motherboard pinout
Same as standerds. In the internal usb conector u can find that there is one pinless & four pin for connect usb.at the pinless side after the pin u put the ground & same line on the opposite u put the red wire.
Jul 28, 2009 | Dell (2336V) Motherboard
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
Need pinout for front pannel connector J60H1
Go to www.intel.com and search for the E210882 number. It is an intel motherboard.
Jun 01, 2009 | Dell Dimension 4500 PC Desktop
I need the front panel pinout on the dell gx60 motherboard
Sounds like a tough one to grab, I've been searching around the internet for about the last 45 minutes, with no success as to finding some kind of readout or diagram of this particular motherboard. Another option, I suppose, may be to bring it in to an authorized service center, and see if a technician can help narrow down where the front panel jumpers are supposed to be seated.
May 06, 2009 | Computers & Internet
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
W2562 Mobo
Your best bet would be to try to trace the pinout using the faulty Dell case. It's extremely unlikely that anyone has done a wiremap for this. Sorry, realize this isn't the answer you're looking for, but is a suggestion.
Sep 12, 2007 | Dell (W2562) Motherboard
Computers & Internet Logo
2,611 people viewed this question
David Payne
David Payne
