Question about Fuji Cameras
Fuji FinePix F810: flash light does not pop up when button is pressed
  • 3 more comments
  • Anonymous Jan 15, 2009
    I have the same problem with my FinePix F 810: the flash does not pop up when the button is pressed.
    Alain Jossin
  • Anonymous Feb 22, 2009
    Me too.
    I hope to get a solution
  • Anonymous Mar 05, 2009
    i have the same problem the flash wont pop up but you hear it click like it wants to pop up .. what is up with this ? its not even a cheap camera ??
  • Anonymous Mar 22, 2009
    Same problem here
    Terry
  • Anonymous Apr 29, 2009
    flash wont pop up...clicks, opens but doesn't pop-up
Hi guys,
I've had the same problem with my f810. I found the solution on a german photography forum:
while pressing the flashbutton with your thumb on the rearside of your camera, push on the body of the camera under the flash on the frontside with your index. try various positions of your index and you'll see: it will open!
neto
Posted on Oct 29, 2009
Thank.. Been wondering about a new camera, but this fix worked a charm.
Well done
Posted on Feb 10, 2010
2 Suggested Answers
  • 214 Answers
SOURCE: fuji finepix f810 flash wont
hi your camera is kind of getting old but it is still great. some people really like it. personally I like also. however, fuji finepix f810 has little problem like yours due to delicate design. on your flash problem could has two sequence check. first is flash circuit defective or flash tube defective. second is main pcb doesn't work properly with flash function. your local repair shop would charge around $75 to 185. Fuji camera usually charge more than other brand. I am sorry that you know. Good luck with you and best regard.
Posted on May 22, 2011
Testimonial: "thats what i have learned from another sorse"
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Fuji finepix f810 flash wont pop up when button pressed
    May 22, 2011 | Fuji FinePix F810 Digital Camera
    How do I fix the pop up flash on my fuji finepix s700
    fix the pop up flash,,,,select manual M operation,flash donot pop up.
    Apr 03, 2010 | Fuji FinePix S700 Digital Camera
    My fuji finepix releases the flash when the shutter button is pressed but the flash does not pop up into place
    Mine did the same thing. The problem in mine after extensive disassembly was the plastic had broken inside the flash where the pop up spring attaches.
    This was a pretty extensive repair with full disassembly in my case, not for most people.
    A workaround is to take a small rubber band, loop it over the top of the camera from the eyepiece for the viewfinder to the lobe in front of the flash. When you need flash, release the flasy and unhook the elastic fromt he front lobe and let it go under the raised flash unit and it will keep it up. If you case lets you, you can leave it that way. Not pretty but functional.
    Jan 04, 2010 | Fuji FinePix S700 Digital Camera
    On the screen there is a picture with a camera and exclamtion mark i dont know what it means
    It's a low light level warning. Push the button on the left side of the flash to pop up the flash
    Nov 30, 2009 | Fuji FinePix S1000FD Digital Camera
    A camera with a club
    Low light level indicator.
    Press the button on the left side of the flash that says "open" to pop the flash up.
    Nov 13, 2009 | Fuji FinePix S1000FD Digital Camera
    I have a fuji f810.the pop up flash will not pop up.
    The problem is the top RH edge of the Flash Assembly becoming stuck under the edge of the top side of the camera case in which it sits. Solution gently prize the flash housing to the left as viewed from the top of the camera case whilst the camera is in the take mode whilst pressing the flash button. When the flash assembly pops up file the RH edge of the flash assembly cover as viewed from the top with a fine swiss file. Take care not to get any filings in the camera. This will totally restore the flash operation to normal.
    Oct 01, 2008 | Cameras
    How do you turn on the flash for the FujiFilm FinePix z5?
    There is a button at the back that looks like a lightning, press that button to turn flash on you will also have choices how you want your lighting or flash just press it to chose.
    Jun 20, 2008 | Fuji Cameras
    FinePix A350 Power Button stays down after being starting camera
    This just plain shouldn't happen. Call Fuji while your warranty is in effect, and have them fix or replace it.
    Mar 23, 2008 | Fuji FinePix A350 Digital Camera
    Flash - how do you get it?
    The button to 'pop up' the flash is located just above the LCD display
    Feb 06, 2008 | Fuji FinePix E510 Digital Camera
    Cameras Logo
    301 people viewed this question
    Top Fuji Cameras Experts
    Steven Wander
    Steven Wander
    Parshiv Luthra
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
