Question about Seiko Premier Automatic Watch Spb001 Spb001j1
How do I reset my Seiko Premier Perpetual Watch
The time & date are working but I haven't worn this watch for months & now the month is showing October when it is February plus the leap year display is wrong too.
escapement
  • 2334 Answers
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
Techjoel
  • 79 Answers
SOURCE: I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Posted on Jun 05, 2009
escapement
  • 2334 Answers
SOURCE: Perpetual Calendar 100M, Ineed the instruction
Follow this link and click on OPERATIONAL GUIDE.
Rate, please.
Posted on Jul 29, 2009
  • 16 Answers
SOURCE: Seiko premier chronograph constantly stop working
take watch to a jeweler, or pawn shop and have it cleaned and oiled.
Posted on Aug 05, 2009
  • 3 Answers
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Posted on Dec 01, 2009
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
Is there any way that I can set my Seiko perpetual calendar watch at home?
What a great watch! It has a super-fine piezo-electronic motor to move the date wheel! Very cool. Its quite a show to go through the date/leap-year check, and then observe the watch catch back up to the correct time afterwards. Battery lasts ~five years.
I downloaded the manual (your model number on watch back) after a short search online (beware of trojans/viruses).
Setting after a battery replacement requires shorting certain pins inside the watch to set the leap-year, and date. The back unscrews, and may require the special watch-wrench, available online. I unscrewed mine VERY CAREFULLY with fine pliers, confirming that I was doing this in a clean, dust-free location. The instructions are quite specific, must be followed carefully to set up correctly. Have a fine wire jumper to set the leap-year. I learned this because I did not want to pay an inexperienced jeweler $100 to replace the battery.
Oct 13, 2014 | Seiko Watches
How to set date on seiko perpetual calendar watch
You can not set the date..it MUST be returned to Seiko for repair. A perpetual calendar watch does not lose the date if it does something is wrong. Seiko will repair for you.
Aug 11, 2014 | Seiko Watches
My armani exchange watch doesnt have month on it just days. some months are only 30 and i am forced to set it up a day every other month and back the next. is there a solution?
there's nothing to be change in your watch. most of watch brands is like yours but there are some watch brand that are selling perpetual calendar watch that you don't have to change every end of the month or even in leap year. if you want that, just look for the "PERPETUAL CALENDAR". I hope i had been helped you.
Aug 02, 2011 | Giorgio Armani Watches
How does its year calendar work?
The day at a glance calendar system used in this Orient watch, has been used in a number of watches over the past 40 years, perhaps most famously in the Wittnauer "2000" watch (which Orient actually made for Wittnauer under contract). Orient itself has used this system in a number of different styles of watches. Note that the daily date window is separate from the day of the week / month at a glance system; the date window is driven in traditional fashion by the movement.
The day/month at a glance system is based on a single disc inside the watch that is manually advanced by the user. If you look at the top of the watch, where the months are listed, you'll see little two-digit numbers. These represent different years--"04" refers to 2004, "11" to 2011, etc. To get the right days of the week at the bottom of the dial, you move the appropriate year under the current month. That will line up the days of the week--Monday, Tuesday, etc.--with their correct dates. You may see the same year repeated more than once on the upper part of the dial because the calendar has a specific pattern that can be replicated.
On older watches using this same system, the top pusher was used to adjust the date window, and a separate winding knob controlled movement of the year/monthly calendar disc. On this specific watch, which I have not handled in person, I cannot see a separate crown to adjust the date, and so I am guessing that you would pull out the set stem part-way to engage the disk setting mode. This would make sense because unlike the date window, where the date is always advanced, the year must move both backwards and forwards to align with all the months in a given year--you'll see that January and October are in the same place on the dial, for example.
If you're interested, here's an example of a vintage Orient that uses this same system for its calendar. Note how the monthly calendar and year/month alignment are flipped from the watch you asked about. Please note that I have no connection with this web site, make no endorsement as to the price being asked for this watch--but it has a nice picture of a classic Orient:
http://forums.watchuseek.com/f30/$128-all-steel-orient-perpetual-calendar-xl-case-vintage-watch-526811.html
On a final note, you'll see a number of people refer to these as "perpetual calendar" watches. That's not accurate. The year / days of the week disc holds about 20 years of calendar information. After that, the disc is no longer accurate, though you can easily keep aligning the monthly calendar just be referring to a printed calendar and adjusting it that way. For a period of time (not sure if they still do it), Orient would accept older watches with this system and change out the old year/day wheel with a new one that went further into the future.
Jun 03, 2011 | Orient CEUAA002WW Wrist Watch
Hello. I have purchased a seiko premier perpetual snp025 watch. From the moment I opened the box the 2nd hand is moving consistently at 2sec intervals and it does not move normally every 1sec. Also the...
Two sec jumps is low power in the elec store,,, winds with movement back and forth as your arm would swing. Sometime the day date function is changed by pressing the small button type crown in slightly with your finger nail.it may have on or two detents if so it adjusts both functions. if not the stemcrown needs to be used to set day and button to set date.
May 09, 2017 | Seiko Premier Kinetic® Perpetual Watch for...
I have a Seiko Premier Kinetic Watch SNP005. The problem is that the date is supposed to change around midnight. Now the date changes around 9-10 in the morning. I have read the manual and the only...
Thank you for contacting FixYa.<br /> You will have to contact Seiko on this one. I would tell you to just change the date to the day before and then forward the time, but I think I would just contact them as it is such a delicate timepiece.<br /> <a href="http://www.seikowatches.com/technology/kinetic/index.html">http://www.seikowatches.com/technology/kinetic/index.html</a><br /> Best regards.
Aug 25, 2010 | Seiko Premier Kinetic® Perpetual Watch for...
Aug 04, 2009 | Seiko Premier SKP085
After replacing battery cannot set mo/day/date
I have the same problem. Watch stores are NO help. Does someone have an answer that works?
Jun 10, 2009 | Seiko SLL086 Watch
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
Jan 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
Seiko Premier Automatic Watch Spb001 Spb001j1 Logo
82 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
