Question about Filter Queen Majestic Canister Vacuum
How to rewire a filter queen power head - Filter Queen Majestic Canister Vacuum
  • james cameron Feb 20, 2012
    It is a central vac power head by filter queen that I need to wire.
  • james cameron Feb 22, 2012
    I have rewired it, black to black, white to white, the bristles are turning but it is blowing out air instead, there is no suction.
2 Suggested Answers
  • 37 Answers
SOURCE: There is no power to my Filter Queen power nozzle. I have cleaned the connection and there is still nothing.
first check the little reset button on the rear of the power head. press it and see if that helps. if not unplug all connections from the hose to the wand and the wand to the head. now plug the head into the hose directly and see if that works. if it does, you have a bad connection at one end of the wand and will need to replace the wand... look on amazon for a replacement... if you want ripped off call
filter queen.
Posted on Jan 21, 2015
Filter queen majestic power head not working, main vacuum working but no power in head when plugged in. any suggestions as to what may be the cause for this to happen.
Is there power at the head, have you checked with a volt meter, most likely if not then the cord to the head is defective.
Aug 31, 2016 | Filter Queen Vacuums
There is an electrical connection at the canister end and again at the beater end. If the beater is not working it is mostly that this is where you problem is. You need to test first to see if there is power at the canister end and then at the beater end. If there is no power at the canister it could be the outlet or something internal. If there is no power at the beater end then that outlet, or the cord could be the problem. If you have power and that end then the problem is likely within the wiring in the beater or in the motor itself
Jan 20, 2015 | Filter Queen Majestic Canister Vacuum
Filter queen vacuum head has no power
More information needed. When you turn on the vacuum do you hear the motor running? Is the problem that there is no suction at the head? Is there suction at the canister when the hose is removed? I would first check to make sure that there is no obstruction in the hose. Have you checked the filters to see if they are clean?
Sep 11, 2014 | Filter Queen Majestic Canister Vacuum
I bought 2 used filter queens. Does the power head always bog down to the point of stalling out when vacuuming. Very strange for a high end vacuum.
I shouldn't. Check the power nozzle brush to make sure it's clean. Remove thread, hair, etc. that may be wrapped around the brush.
Check the tautness of the belt. If it's too tight it will cause strain on the motor, which will result in this.
Check the ends of the brush. They may need cleaned, or the bearings may need replaced.
I highly recommend taking it to an authorized Filter Queen distrubuter for diagnosis and repair.
There are instructions for replacing the brush at the following site, if you decide to do it yourself.
http://reviews.ebay.com/How-to-install-brushroll-for-Filter-Queen-Vacuum_W0QQugidZ10000000010317007
Mar 02, 2011 | Filter Queen Majestic Canister Vacuum
How do I change the power cord on my Filter Queen vacuum cleaner?
First, remove the top filter cap. quarter turn.
Remove the three screws from under said cap.
The rubber switch cover will come off of the on/off switch pedal there. pull off and set aside.
undo the two clamps and remove the motor (chrome) section from the base.
give the handle a tug and the chrome cap should now come off and allow you access to the wiring and motor/switch.
optional side note: at this point you may want to replace the sponge filter around the motor too.
Remove the cord from the unit and rewire to the same spots the old cord comes out of.
reverse the instructions to put the machine back together.
Nov 05, 2010 | Filter Queen Majestic Canister Vacuum
Belt on power head breaks frequently
1. Make sure you're replacing with genuine Filter Queen belt.
2. Avoid vacuuming items that will roll up on the brush. This creates stress on the belt and will weaken and/or break it.
3. How frequently? "Frequently" is a relative term. On some vacuums, once a week is "frequent", on others, twice a year may be.
Aug 22, 2010 | Filter Queen Majestic Canister Vacuum
The power head on my vacuum keeps shuting on and of when vacuuming carpet
the electric cord may be loose on the head. I have had this happen on my other power head vacuum. you may not be able to fix it.
Aug 12, 2010 | Filter Queen Majestic Canister Vacuum
Just stopped working
mine has a reset on the power head. alittle red button the back. if it is that old and worn out i would buy a refurbished one on like think i saw one for around $350. just search filter queen and u will find them
Aug 20, 2008 | Filter Queen Majestic Canister Vacuum
Power head is dragging slowing down like the brush is stopping turning and coming back
Have you tried changing he belt ?. Some time the belts stretch out and they don't turn the brushes
Jun 13, 2008 | Filter Queen Majestic Canister Vacuum
Filter queen spitting more than sucking
Usually this means that you have a clog, either in the hose, wands, or by the brush roll in the power head.
May 05, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
54 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
