Question about Sewing Machines
Viking 6570 feed dogs to low to take material through - have no maunal
MakikiChris
  • 84 Answers
SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
bargainbox
  • 1388 Answers
SOURCE: feed dogs not feeding the material
Is this a second hand machine ?
Is the stitch length selector set to > 1
Remove the needleplate and clean between teeth of feeddogs if it has been a while since this has been done, old lint will impede feeding.
Presser foot tension for general work needs to be set at 3, or the chromed button pushed down to the grooved line, depending on machine.
If new, call the dealer where you bought it and speak to them.
Posted on Nov 24, 2008
bargainbox
  • 1388 Answers
SOURCE: Simplicity Serger pro 432-- feed dogs will not
The most common troubles with feeddogs not working properly is either lint trapped in between the feed teeth...remove the needleplate and clean out the lint which may look like felt in extreme cases. or... the presser foot tension is too low, in which case, increase tension...there will be a knob of some sort at the top of the machine directly above the Presser Foot Shaft. It is a remote possibility that the feeddog height needs adjusting ...it will have been a major trauma of a severe jam or tugging etc to cause this. As it would almost certainly result in other timings being affected and particularly in the case of a Serger/Overlocker, the added risk of breaking loopers (expensive), I would recommend a service by suitably qualified technician to restore all to optimum condition.
Best Wishes Martyn
Bargain Box in Australia
Posted on Sep 08, 2009
  • 152 Answers
SOURCE: The feed dog is not grabbing the material or the
The little white button on the lower right front of the machine is the button that drops the feed teeth. If it is pressed in the feed teeth are down, push in a lift upward to be sure it's in the "Up" position. Then look on the left side of the machine, you'll see a dial, (NOT the dial facing you as you sit in front of the machine) make sure the red dot on the dial is lined up with the red dot on the painted part of the machine.
Finally look at the dial on the front of the machine. The one with the little button in the center of it. Put it on the number 3. If your machine doesn't feed fabric after doing what I've outlined then you need to take it in for service.
Posted on Oct 23, 2009
Feed dogs not pushing fabric through
Remove the needle plate and make sure there is no lint obstructing the feed dogs. If they are clear, it is usually the feed dog step motor gone bad. You should have your machine serviced by an authorized Husqvarna Viking dealer. You can find your nearest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Sep 26, 2014 | Husqvarna Viking 1
Feed Dogs wont move fabric on a Viking Prisma 990
the feed dogs need to be checked, they may need some type of adjustment.
May 03, 2013 | Sewing Machines
I have an Emerald 203 When I hit the presser foot, the wheel goes round and needle moves up and down but the material does nt move
it sounds like the feed dogs are not working, if you have a manual
check and see if there is a lever to move the feed dogs up and down
and see if lever will move the feed dogs, if that lever doesn't then
the feed dogs will have to be checked.
here is a link for a manual if you don't have one
http://www.scribd.com/doc/104663888/Husqvarna-Viking-Emerald-183-203-User-Manual
Dec 14, 2012 | Husqvarna Sewing Machines
The fabric doesn't seem to feed as well as it should while I'm sewing.
Look to see what the height of the presser foot is. A nickle laid beside the feed dogs for comparison will give you an idea. Its height should be the same or slightly less than the nickle. In the high position, at the top of the needle stroke. 1.m.m is the correct height. Worn feed dogs, thick heavy material and binds in the feed nechanism will do the same.
Derek
Jan 17, 2011 | Husqvarna Viking 1
Raise feed dog
I have a different model Viking with a feed dog button to the left of the power button. When it's pressed down, the feed dog stays in the "down" position. Press it again to bring the feed dog up.
May 19, 2010 | Husqvarna Viking 1
Transport blocks
Sounds like the feeding mechanism is having problems. The feed stepper motor is probably getting reset telling the feed dogs to move up and down rather than backward and forward. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Mar 19, 2009 | Husqvarna Huskylock Computerized 905
Feed dog switch
Oct 27, 2008 | Husqvarna Viking 1
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
