Question about Garden
RBC30SET worked fine but having run ou of fuel now won't even turn over
Having exhausted one tank of fuel and refilled I went through the start procedure but cannot get the electric start to respond at all
    Sergeant:
  • 316 Answers
Hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Posted on Feb 19, 2012
97 mercury mountaineer. won't start
hi,
watch your oil pressure when cranking, you have to have some oil pressure to get the fuel system to start. you may have to find the hot wire at the relay and energize it to see if it is indeed the fuel pump going out. if its been sitting and its a 97 the fuel pump just might have went, you can also try hitting the gas tank from the outside in the middle to see if that works too. have a water hose or fire extinguisher around when your working on fuel system and leave one of your battery cable a little loose..
jm
Jul 04, 2017 | 1997 Mercury Mountaineer
Chevy Malibu 2003 cranks but won't start! I know
You might have a defective fuel tank pressure sensor!
May 05, 2012 | 2003 Chevrolet Malibu
1991 eagle talon will crank, but won't start up. 2 days ago I was driving home from work when i turned around in a parking lot and went to my parents house. about a half an hour there i needed to move...
That sounds like the fuel pump may have lost it's prime. Does it have fuel injection, or a carburetor on the engine? How much gas was in the tank while it was parked on an incline? Have you tried any starting fluid sprayed into the air intake hose, toward the engine? Warning! Don't use much starting fluid! Perhaps a one or two second burst, and have someone crank it immediately after you have stepped back at least 6 feet from the engine. If it fires, then it is definitely a fuel delivery problem! But it won't run long like that unless the fuel pump starts working again ... which is most likely when the engine is cold!
Apr 19, 2017 | 1991 Eagle Talon
I have a 2001 Chevy Malibu 3.1 Liter. I was driving it last night, and I parked it, everything was fine. 15 minutes later I had to go somewhere, went to fire her up, and it wouldn't start. It's...
Assuming there's enough fuel in the tank - If the fuel filter is extremely clogged - try starting with the fuel cap off so it won't have work against the vacuum in the fuel tank. Fuel caps have breather holes which can be clogged also. The holes release the vacuum in the tank slowly. If it starts ok then, the problem sits in fuel supply - for example the fuel filter.
Smell the exhaust pipe - if it smells strongly like petrol, most likely it's the ignition system requiring service. (sparkplugs, distributer, sparklines)
Jul 01, 2011 | Chevrolet Malibu Cars & Trucks
I have a 1999 gmc sierra with (as of 30 days ago cat. converter, fuel pump and filter, cap and rotor) changed in garage. regular oil changes, tune ups as of 8 mths. it has lots of cranking power, but...
If i understand you right the truck has been sitting for two years.If it has been sitting that long without running or moving the gas has turned to varnish...I suggest that you drain and refill the fuel tank,and replace the fuel filter located on/in the frame rail on drivers side.
Jun 18, 2011 | 1999 GMC Sierra
1993 dodge ram van 250 sometimes starts and runs for 2 or 3 days and then stop and won,t start again for days and when it start again it pops and spudders for awhile and thenit straighten out andruns a few...
Use fuel line/injector cleaner this is a common problem. Also try higher octane gas for a tank or 2 and get her ou on the highway and blow he cobwebs outta he fuel system and exhaust
Jun 09, 2009 | 1993 Dodge Ram 250
95 4runner
check your asd relay or fuel pump relay
Aug 16, 2008 | 1995 Toyota 4Runner
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
