Question about Haier HWD1000
HAIER HW-C1270TVE-U Washing Machine
Wondered if u can help me as i cant find the instructions, cant open the door its as though the programme is stuck its on o mins on quick wash
5 Suggested Answers
  • 43 Answers
SOURCE: Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Posted on Nov 11, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Front loading Haier HW-D1470TVE Door will not
Sounds like your door is locked. Unplug the unit for 30 minutes then plug it back it hopefully it will reset everything and you will be able to open the door. Then after you get the door open you will need to run some tests to see what is the problem. Check the door lock sensor and the door lock mechanism
Posted on Feb 19, 2009
SOURCE: My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Posted on Mar 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: hiaer hw-c1270tve-u washing machine error code 8
It appears your pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
Jan 07, 2010 | Haier Washing Machines
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Hw 2 open the washiingb mashine door?
First you must check if there is power in your wall socket, then turn on the machine, try to gently open the door (the door has a catch). If it still does not open, press the 'end of cycle' button.
Click on your model number (below FIXYA) on this website, type in & search. You will get a shortlist; click on your model, below the page you will get Manual/Guides. Click on the blue, you have your manual on line. If available that is............
Feb 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front loading Haier HW-D1470TVE Door will not open. This inspite of the wash programme having ran and the digital dispkay reads "end". What can I do?
Feb 19, 2009 | Haier XQG50-11 Front Load Washer / Dryer
Hiaer hw-c1270tve-u washing machine error code 8
Dec 29, 2008 | Washing Machines
Zanussi Electrolux FX 1265 W washing machine wont work
Chrisbounty
also not ure what you meant by fused did you have some kind of electrical arcing sparking wires melting?
Sep 20, 2008 | Washing Machines
Haier HWD1000 Logo
78 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
