Question about Plumbing
My washer keeps showing e40 - Plumbing
Built in machine. It show error e40. What does it meant
Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of “E40”. I am showing that an “E40” error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
Mar 23, 2016 | Electrolux Washing Machines
My electrolux washer dryer ewx14540w keeps flashing e40 and won't do anything, please help
Hi dear.Related to your problem,E40 means:
• The door is not firmly closed. (E40)
• The machine is not plugged in or there is no power
at the socket.
• The main fuse has blown.
• The type of fabric has not been selected by means of
the relevant selector dial.
• The Start/Pause button has not been depressed.
• The Delay Start option has been selected
Please checked those followings.I hope that helps.Thanks.
Feb 13, 2011 | Electrolux EW1209i Front Load Washer /...
My zanussi washer dryer keeps flashing E40 whenever I try and do anything
can be faulty door lock or wiring to the lock. also door ****** can be displace in the door . the handle shaft can slip out this stops door closing and actuating the switch correctly.e40 relates to starting the machine with door open.
Aug 03, 2010 | Zanussi Washing Machines
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
May 21, 2010 | Electrolux EW1000i Front Load Washer
E40 error door light flashing and clicking noise
E40: Door open, Interlock, wiring or main PCB most likley going to be faulty door interlock.
Turn the power off, unplug the machine and take the top off your machine and on the front right of the machine there is a plastic case with lots of wires.
Put the wires out one block at a time, keep putting them in and out, this will help the connection to seat.
Try the machine again and the problem should be solved.
If not you may need a new board.
Mar 10, 2010 | Zanussi IZ161S Front Load Washer
E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Feb 20, 2009 | Zanussi ZWF1430W Front Load Washer
Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Nov 14, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zwf1631w error code e40
hiya
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi zjd1219
Hi
Machine is showing E40 ERROR
Sep 07, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
