Question about Pioneer Audio Players & Recorders
Right channel on receiver not working. It is very quiet for a and b hookups. Left channel is fine. Pioneer vsx9500s
silly girl
  • 513 Answers
SOURCE: onkyo srtx601 receiver
Please add a comment to your previous post next time, it makes it easier to see this post has a relevant history. I had to go check in your profile when I saw the word "still". Shooting in the dark, and saying the obvious(just bear in mind a month ago I was going crazy over a problem that ended up being the blanace knob turned to the right) - could it be that you're not using a digital signal? I'm not sure you can get surround with analog. Make sure all settings are for digital, and that you're using a coaxial/optical cable going from the DVD to your receiver. I hope you'll end up embarassed but happy. Good luck
Posted on Jun 19, 2006
VOTIT
  • 2071 Answers
SOURCE: broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Posted on Jul 27, 2008
SOURCE: Pioneer SX-750 Old School Need Help
Check the speaker wire. Sometimes it can just be loose in the terminals and cause distortion. I have had the problem before.
Cheers!
DellMan94
Posted on Jan 12, 2009
lynchms
  • 93 Answers
SOURCE: Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Posted on Jan 28, 2009
  • 93 Answers
SOURCE: Quiet front R channel on Sony
Does problem persist when you connect other speaker to front right channel? (i.e. when you connect your FL speaker to FR and vice versa)?
Posted on Jul 15, 2009
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
I have a Pioneer VSX 452 receiver. I am trying to run a second set of speakers off the b channel and use the a and b switches on the front of the receiver. If only the a channel is depressed the two...
Thanks for the detailed explanation...
It seems to be there is a short or misplaced (+) (-) leads on the speaker connection you made..sometimes a tiny cable piece can make a short in between the leads and cause such problem..My recommendation is:
** take all the wires off..
** install only B speaker leads and test it..( make sure LEFT and RIGHT (+) and (-) leads properly
and individually connected to the right places on the back......it is important...This causes balancing problem..
** if it works fine...
** than go ahead and install the A speaker leads..and test it..
if you do everything properly both A and B speakers should work fine as independently ...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Pioneer VSX-454 Receiver
I'm connecting Bose 901 speakers with an Active Equilizer hookup required to my new Pioneer VSX-520. What in/out puts should be used ??
The solution to using 901's in a multichannel rig works best when you have individual Front Right and Left Pre-Outs but this receiver doesn't have them so a compromise is in order.
First some background.
The use of 901's Active EQ (or any external processor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's.
http://www.retrevo.com/support/Pioneer-VSX-520-K-Receivers-manual/id/23653ag911/t/2/
This works for all models of AV receivers when you want 901's as Front L&R speakers...
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them, in your case maybe the CDR or DVR/VCR outputs.
On many AVR's, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others (yours), you have to borrow the signals from a typical CDR or DVR/VCR Output RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won
Feb 13, 2011 | Pioneer Audio Players & Recorders
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Jul 15, 2009 | Audio Players & Recorders
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Pioneer VSX-D903S
just try prologic mode no tv uses 3 ch nomore ok and turn on ch a speakers only
Jan 29, 2008 | Pioneer VSX-D908S Receiver
Left Speakers not working on A or B channel
Have you tryed yet to switch the right speaker where the left one is? If it works then you know the speaker is bad. If you move the left speaker over to the right channel and it works and sound now comes out of the left speaker, you know there is a fault in the amp somehwre. If your not a tech and have not had any solid state equipment repair experience, then your going to have to have the amp serviced by a trained tech.. Good Luck
Oct 30, 2006 | Pioneer VSX-454 Receiver
73 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
