Intertherm Thermostat I bought a programable thermostat to replace the intertherm. I am confused about the wires. The intertherm has an x wire, it is black but there is no x wire option with the new thermostat which is a Hunter 44860.
    New Friend:
  • 30 Answers
The wire that is on the x- terminal  on the old tstat will be c-terminal on the new tstat.
Posted on Oct 30, 2008
Need a wiring diagram for a EEH-012H intertherm
Request the wiring diagram from Hunter and, if need be, Intertherm.
Feb 12, 2018 | Hunter Heating & Cooling
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
Intertherm air conditioner won't work
First I must ask...does the compressor come on? does it just sit there and make a clicking noise? If it doesn't come on at all and if you are handy with a screw driver and can do electrical type work you can take a piece of insulated wire and jumper the thermostat (put insulated wires between the terminals the wires connect to). If it comes on and blows cold air replace thermostat.
Aug 15, 2014 | Intertherm Heating & Cooling
Intertherm wiring diagram for model number MGHA-056ABFC-05
you have a 24 volt shorts check your thermostat wires to see if they are frayed or if they are touching anything. Check your outside wires also go to the thermostat.
Jul 12, 2014 | Intertherm Heating & Cooling
My intertherm furnace blower stops coming on. If I turn the thermostat up and down several times it will work properly for about a day. then will start doing it again. I have replaced the thermostat and...
Turn the power off to the unit and use a different color thermostat wire in place of the green wire. If this works, there is a short in the wire. If not it's likely either a relay or a bad motor.
Nov 05, 2013 | Intertherm P3RA-048K Air Conditioner
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
Wiring in a new thermostat
yes .common as in the netural side of the transformer x to cif not hooked up the stat will still work. and honeywell has good support for their products . Tom
Jun 20, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm Heating and Cooling
I would say that you have ether a wiring problem or a faulty thermostat. The thermostat brings on the A/C through the Y terminal on your thermostat. The heating is brought on by the W terminal on the thermostat. If the wire for the A/C is shorting to the wire for the heating it would give the problem you are describing.
Jul 21, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
808 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
