Question about Sys Technology SYS 152L-C-JT (Chrome) 15 in. Flat Panel LCD Monitor
Monitor dead-in-the-water Monitor does not turn on. No power on light. Pushbutton switch is ok. Internal fuse is ok. No obvious defect. Please suggest next step.
0 characters
1 Points
It will not work i switch it on and nothing happens
Remove cable connecting monitor to computer, turn it on. If you see a "NO SIGNAL" note, your monitor is ok and the problem is the graphic card of your computer. If you've recently removed and reconnected the monitor, might be a bent pin of cable input.
If Monitor is dead when you turn it on disconnected, it's defective and you should repair it
Apr 26, 2015 | Computer Monitors
Will not switch on, no green light totally dead?
These units are known for having issues with the internal power supply board. There are parts called capacitors that fail due to heat buildup in the monitor case. When they die the power supply stops working and you get a dead monitor just like you have. If you can solder then you should be able to repair your unit. We have a free step by step repair guide posted on our web site at: The repair should take less than 20 minutes to do and cost less than $15 for parts.
I hope this helps, if so please rate our solution.
Corporate Computer
Sep 15, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor shows no power light and won't switch on
There probably will be an internal fuse but a warning even when disconnected from the mains your monitor can give you a bad shock and the fuse has probably gone due to another failed component
my advice if unsure let a qualified electrician test it
Feb 25, 2010 | Computer Monitors
No power/dead
try to turn it on the power switch on monitor.....and make sure all connection are ok
Mar 06, 2009 | BenQ FP731 - 17" LCD Monitor
Power problem
for the quickest fix, you should try a new power supply cord and see if its just a bad cable. almost any monitor cable (dell brand) should work. if you do not see any of the lights on the monitor light up then you have an internal problem and it will be costly to repair. probably better of buying a new monitor.
Sep 25, 2008 | Dell E153FPT 15" Flat Panel LCD Monitor
Dead monitor dell e173fp lcd monitor
This could be either down to an internal fuse blown or the main board or the capacitor on the power supply could be faulty.
Sep 04, 2008 | Dell E173FP 17" LCD Monitor
Dead Proview 700p monitor
my monitor samston 17`` have a problem with screen ten minute after on it`s become on / off screen ( it`s black, it`s white ) when it`s happen the wording can read, when it`s on.
Jun 25, 2008 | Computer Monitors
Dell E197FP LCD Monitor won't turn on completely dead
could be dead, but check to ensure that you are using the monitor ONLY, not TV tuner device. as a standalone, not hooked to cpu if there is no power light when plugged in assume your buying a new monitor.
Jun 21, 2008 | Dell E197FP LCD Monitor
Monitor is black, the blue lcd at the switch does not lite when switch is turned on. The internal fuse is ok. I tried to find a schmatic on I could check the power supply, no luck.
I have the same problem. Took it apart for troubleshooting. Found that if I disconnect the ribbon cable between the display driver circuit board and the LCD panel, I can turn on power and it will stay on. I can turn it on and off with the power switch. With the LCD panel cable connected, Power turns on (power light blinks) then apparently a fault with the LCD panel causes the power supply to shutdown. At this point the power switch does nothing. Now the big question is "Can you purchase a LCD panel?" If so, it probably costs more than a new monitor. Hope this was helpful.
Jan 02, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Monitor won't power on
PF747 has internal switch-mode power supply. Old LCD monitors have external low voltage (12VDC) power supply which can easily be replaced by any brand provided the voltage and current is the same. On your monitor, th epower supply module is built inside the unit. When you say that the LED is flashing, this means two things, 1. The power supply is attempting to start, but the load (or current) is above its limit and it automatically switch off, then tries to start again and so on. This can be a problem with the load (minitor intelligence or the mainboard, hv supply for the flourecent back supply) 2. It can be that the power supply module is defective In any any case, the only way to find out is to disconnect the load from the internal power supply (the monitor have to be opened), and measure the voltage at the terminal. In many devices the output will be 12 volts and in some cases there will be also 5volds supply. If there are correct voltage present, then the supply is OK and most probably the mainboard or the HV supply is defective. If there are no voltage present, then the power supply module is defective. You can either fix this module, replace with exact new module or if you have a spare external powersupply, you can use this to provide the power to the internal circuit. The last option is recommended only if you have experience in electronics repair. If you cannot do the repair yourself and will cost USD200, buy a new monitor.
May 18, 2007 | BenQ FP747 (Beige) 17" LCD Monitor
Sys Technology SYS 152L-C-JT (Chrome) 15 in. Flat Panel LCD Monitor Logo
18 people viewed this question
Top Sys Technology Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Sys Technology Computer Monitor Expert? Answer questions, earn points and help others
