I have an Acer Aspirie One ZG8(AOD250) with NO display. How to get it working?
It had an external monitor attached via DVI cable and was working. Moved it and the cable came off. Re-attached cable and nothing...re-booted without external monitor and no native display. Tried re-booting and hoping F1 or F10 would display something...no go.
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Feb 20, 2012
How do i fix white screen on my kav60 acer aspire one
The KAV60 is also the AOD250.
Netbook OFF, monitor OFF, connect an external monitor to the netbook's VGA port.
[You can use a VGA monitor. Looks like a small TV.
This is an example of a VGA port,
VGA connector Wikipedia the free encyclopedia
Note* VGA port doesn't have to be blue in color ]
Turn the monitor on. Turn the netbook on.
If there is no image shown on the external VGA monitor, press and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(The F5 key is the Display Toggle-Over key)
No image on external VGA monitor?
Hold the Fn key down once more, and tap again on the F5 key.
Still no?
Problem is internal in netbook. Probably graphics chipset soldered to the motherboard.
Replace motherboard.
Image shows on external monitor?
Problem is with Video Cable or laptop LCD screen.
MOST of the time it's the Video Cable.
The Video Cable connects to the motherboard, in an area under the Keyboard. It then routes up under the left Hinge, and into the Display Panel.
Inside the Display Panel it then connects to the LCD screen.
With frequent opening and closing of the netbook, the Video Cable can be pulled on. This can cause damage to the Video Cable.
(Stretched/broken wires inside the sheath of the cable)
And/or it can cause the connection at the motherboard to be loose, and/or at the LCD screen.
Example of Acer Aspire One video cable,
For ACER Aspire One D250 LCD Screen Cable DC02000SB10 KAV60 New
You can remove the Video Cable, and check it's continuity with a multimeter, or if the cost is reasonable to you simply replace it.
8 to 10 dollar video cable is not the problem? Then problem is the LCD screen itself.
My money is on a loose video cable connection, or damaged video cable.
For additional questions or to have me clarify/simplify anything in my solution, please post in a Comment.
Regards,
joecoolvette
Jan 15, 2015 | Acer Computers & Internet
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Acer Aspire One ZG8 drivers
These are freely available for the netbooks including the aod250 Acer aspire one zg8.
http://us.acer.com/ac/en/US/content/drivers locate model number on rear panel if netbook.
Aug 03, 2014 | Acer Aspire One A150-1006 Notebook
HEY
Hi, Simply attaching the cable isn't always enough. Sometimes you actually have to tell the laptop to display via HDMI or DVI onto your external monitor or it will not output any signal.
Try pressing Windows Key+P, this will change your presentation settings in Windows (What screens you get a display on and how they are displayed). Cycle through to either "projector only" or "duplicate screens" and see if you get a display on your TV then.
Mar 20, 2014 | Philips 42PF9630A 42 in. Plasma Television
Unlock password
How about looking at a screen?
Use an external monitor
Briefly;
Your laptop has an external display device port. (Connector)
I do not know what it is, because you didn't state the laptop manufacturer name, and model number; Elizabeth
It may be a VGA port, or HDMI port, or Mini-HDMI port; or DVI port
http://en.wikipedia.org/wiki/VGA_Connector
(Scroll down for VGA Cable example)
http://en.wikipedia.org/wiki/HDMI
(You can click on any photo, and it will enlarge)
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Laptop OFF, monitor OFF, connect the external display device to the laptop.
(VGA = Monitor. DVI = Monitor. HDMI, and Mini-HDMI usually = HDTV. They all compromise an external display device)
Turn the monitor/HDTV on.
Turn the laptop on.
By factory default settings, the display should show on the external display device.
IF not;
There are at least 3 display options. For this example I'm going to use a VGA monitor.
(For a VGA monitor you can use a CRT type of monitor. Looks like a small TV. Or you can use a flat LCD screen monitor, if it has a VGA Cable attached)
The basic 3 display options using a VGA monitor are;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time tap once on the Display Toggle-Over key.
Which key is that? Dunno. Laptop manufacturer name, and ......................
It will be one of the F keys at the top. F1 through F12.
The Function key will have a monitor icon on it, and usually an arrow on one side........Or perhaps two monitor icons sitting side by side.
(Empty rectangle is a monitor icon)
Still no display on external display device?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key
[If memory serves for Display Toggle-Over key;
HP = F4
Acer = F5
Toshiba = F5
IBM/Lenovo = F8
Don't write that in stone, however.......]
Once you post the manufacturer name, and model number; then I can guide you step by step.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
My Acer P205H shows up for 1-3 seconds before showing a black screen. Connected DVI Cable but is there a need to connect vga too?
Depending upon the video port/s you have on the graphics card, you need to connector one video cable, either the DVI or the 15pin DSub to the monitor.
Sep 12, 2009 | Acer AL1916W 19" LCD Monitor
Acer lcd monitor attached to dell computer optiplex gx620 have windows xp professional default is plug and play won;t recognize monitor. have service pack3. in device manager under monitor only plug...
Is it attached to your computer via a VGA cable or DVI cable if it is vga then that is your problem
If your graphics card does not have DVI then you will not be able to make best use of that monitor.
Aug 20, 2009 | Computers & Internet
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
Dell 410XPs + Dell 3007WFP monitor issues
Vinod,
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
