Question about Ashampoo ClipFinder HD
Categories and their vid clips "lost" from my videos screen
Downloaded vid clips fine, set up new categories and moved all but five clips to them. BUT On next load of the program, only the five clips in the default category show on the "my videos" screen! Other categories have vanished, along with (apparently) the downloaded clips that were in them. BUT all the clips show when I click on the download manager screen, and can be played (but not moved from) there. And they all show in the folder on the C drive. Any thoughts? Quite prepared for it to be something stupid I've done!
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Black screen when taking pictures and videos.
I just had this problem! And the answer is simple - just hit the DISP. button and the image should return.
May 28, 2010 | Canon PowerShot SD1100 IS Digital Camera
Down load screen frozen
I opened it up and let the battery run down the power after five minutes i reasembled and went to settings and reset to factory defaut settings it restored it, its working fine now, i lost my muscic but a can always download again !
Dec 25, 2009 | SanDisk Sansa e260 MP3 Player
When its charged it fine but five min. after using
you are overloading it.
the information you have on it is to hard for it to read.
Nov 29, 2009 | SanDisk Sansa Clip MP3 Player
Ipod Classic 120GB video problem
where did you get the vids from. it sounds like the codec used for the vid is not ipod compatable. you may be able to convert them using free software like anyvideo converter or ipod robot. i tunes can play them because it has a greater library of video codecs (anything installed on the system... almost)
Aug 14, 2009 | Apple iPod MA446LL/A MP3 Player
I have lost the ks41010 s-video out cord any way to repalce it???? Thanks in advance
S vid cords are cheap. You can find one at any tech store for about five bucks.
Apr 20, 2009 | Koss KS4110 DVD Player
Hitachi ultravision 50v500
there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Convergence
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Editing kodak easy share video clips
Kodak pocket video camera captures video in .MOV format, however, Windows Movie Maker only accepts video in .AVI, .WMV, .MPG extension.In this situation, iOrgSoft Video Converter is a good assistant for Kodak pocket video camera. It is engaged in converting Kodak MOV video into any popular video format, such as AVI, WMV, MPG, ASF, MP4, RM, RMVB, VOB, FLV, SWF, MKV, etc.
Sep 07, 2007 | Cameras
Computers & Internet Logo
29 people viewed this question
Top Ashampoo Computers & Internet Experts
ray gallant
Tom Chichester
Nitesh Sharma
Nitesh Sharma
Are you an Ashampoo Computer and Internet Expert? Answer questions, earn points and help others
