Question about LG DU-37LZ30 37 in. LCD HDTV
LG DU-37LZ30 power light flashes red to green and won't turn on
My LG 37 inch DU-37LZ30 won't turn on. When plugged in the "power standby indicator" or power light flashes red to green and nothing seems to help. Any suggestions please? Thank you!
  • 5 more comments
  • dmcbrearty Nov 05, 2008
    Same exact problem.  Did you ever find a solution?
  • DEDE3530 Nov 22, 2008
    I HAVE A MT2025D HDTV LCD 20 IN, AND IT IS DOING THE EXACT SAME THING AS YOU'RE DESCRIBING, HAVE YOU FOUND ANY SOLUTIONS YET?
  • canjen62 Dec 05, 2008
    I am having the same issue. Our power to the house went out and when it came back on the powerlight on the front of the tv was flashing red and green but wont come on. Our tv is plugged into a $250.00 surge protector and evenything else plugged into it is working fine.
  • Anonymous Jan 09, 2009
    you mean to tell me with all these same questions about the flashing pilot light, there is still no solution? I'm dying here. Turned the tv off fro about an hour, turned it back on and get nothing but the powerlight flashing fast between red and green. Any factory folks out there?
    Please respond to spaminc@comcast.net as soon as possible. I am taking classes via my cable/college and I missing stuff left and right. Thank you.
  • Anonymous Jan 16, 2009
    Same model ( LG DU-37LZ30 ); Same problem.
  • mowens569 Mar 04, 2009
    power failure causes flashing green and red power standby light to flash. unit will not turn on
  • ukez Apr 24, 2009
    LG 32" I'm having the exact same problem, did anyone manage to resolve this issue?
    ukez@hotmail.com
5 Suggested Answers
stradeteox
  • 88 Answers
SOURCE: LG DU-37LZ30 goes blank on it's own...
This is a bad digital main board. Having to unplug and plug it back in is a dead giveaway for this problem. The part number for the main digital board is 3313TD3014A. Hope this helps.
Posted on Jan 08, 2009
  • 25 Answers
SOURCE: lg tv modle DU-37LZ30 on off indicator light is
Most likely a power supply problem. I recommend taking this to a certified technician and having them look at it.
Posted on Nov 05, 2009
snakehead
  • 1074 Answers
SOURCE: I have a LG 37
it will be very expensive to repair your tv my advise is to buy a new tv.good luck
Posted on Mar 01, 2010
  • 8457 Answers
SOURCE: power indicator flashes red/green. does not turn
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 10, 2010
Testimonial: "Thank you for the fast reply."
ladywinn
  • 5138 Answers
SOURCE: My LG DU-37LZ30 worked fine
llok for Bad Capaciotrs on power supply board they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
Posted on May 31, 2011
Power indecater light stays red flashing green with clecking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 16, 2016 | LG DU-37LZ30 37 in. LCD HDTV
Red green light flashing with a clecking noise
LG 37LC2D will not turn on
mine just did this tonight as well.... no answers yet?
May 09, 2010 | LG DU-37LZ30 37 in. LCD HDTV
Power indicator flashes red/green. does not turn
Apr 10, 2010 | LG DU-37LZ30 37 in. LCD HDTV
Lg tv modle DU-37LZ30 on off indicator light is
Nov 04, 2009 | LG DU-37LZ30 37 in. LCD HDTV
Power led blinking red and green wont turn on
For LG DU-37LZ30 specifically - On the power supply board, look for IC101, an 8-pin DIP IC. There will be three smaller electrolytic capacitors near it (C107, C113 and C125) marked 47uF, 35V. I'm being lazy here, but replace all three (only one is the real culprit). What is happening is that one of these caps is charged by line voltage until the IC (power supply controller) can start running. When this capacitor gets leaky, it cannot reach the proper voltage to start the controller. I used a 47uF, 50V replacement.
I have fixed two LG sets with this same problem. The other was a 26". It's a cheap fix!
Nov 02, 2009 | LG DU-37LZ30 37 in. LCD HDTV
Blinking power light
This set has a power supply and signal PCB. Since the indicator light is blinking, I would consider the problem to be a missing voltage from the power supply. Unplugging the set for a couple minutes may solve the problem. If not the set may still be under warranty. Contact LG (800) 243-0000 for a servicer in your area. Hope this helps.
Apr 28, 2007 | LG DU-37LZ30 37 in. LCD HDTV
LG DU-37LZ30 37 in. LCD HDTV Logo
1,635 people viewed this question
Henry  Thomas
Henry Thomas
