Question about RCA D52W135D 52 in. TV/DVD Combo
No Picture - need new lamp?
No picture when powered on. Sound comes on, and green power light comes on.
chris5563
  • 37 Answers
SOURCE: tv dont come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Posted on Nov 07, 2007
  • 3 Answers
SOURCE: no picture
Sounds like it could be the entire light engine.  The part is available on the Internet, but it runs $700 - $1200 without the lamp (although it sounds like you could use your existing lamp without a problem). These parts, however, are notoriously hard to find and may be backordered for months.
May not be worth the cost, but that's up to you.
Posted on Jan 08, 2008
muttandjeff
  • 359 Answers
SOURCE: TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Posted on Feb 06, 2009
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
rustym62
  • 201 Answers
SOURCE: RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Posted on Apr 26, 2009
Green Power light blinks for about 60 secs, then
YES New lamp needed the model number will be on old one does not take long to change if still got hand book shows how change
Nov 07, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture with sound
yes , u need a new lamp shop around , cost less
May 08, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
My tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
Apr 07, 2009 | Samsung Televison & Video
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Green light flashing & no picture on Toshiba 40pw13p
There is problem with the lamp. It might need to be replaced. The lamp unit is on the bottom-left side of your TV. Loosen thumb screw (by hand) to take the the lamp unit door. Using a screwdriver, loosen two screws of the lamp unit and carefully pull the lamp unit out.
Put a new lamp in reverse order.
Jun 28, 2008 | Televison & Video
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
RCA D52W135D 52 in. TV/DVD Combo Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
