Question about Pogo RipFlash Plus MP3 Player
Driver for pogo products ripflash 128MB DL
I can't locate a driver for the pogo products ripflash 128MB recorder. Is there a way to get the data off without a driver? I have tried connecting it to my PC but it does not show up in My Computer. I have WinXP.
Rob
  • 2 more comments
  • Anonymous Nov 17, 2008
    POGO NO VISTA DRIVERS
  • Anonymous Jan 13, 2009
    Yeah, I have the same problem. I think the company went out of business.
  • dikoneo Feb 11, 2009
    Please somebody help!!! Can we install similar drivers?? Or somebody with them would be willing to upload them?
  • emi8901 Feb 23, 2009
    I can't find the drivers and the Mp3 manager software to my old ripflash plus, Is Anyone be able to find them?  or may we have another way get out the files from the mp3 player without the factory software?
Http://75.127.97.193/files/PogoMP3ManagerCD.zip
Posted on Jun 07, 2009
  • 24 Answers
I have the driver CD. barrylevine(at)att.net
The Win2k/XP driver will not install properly, but it works under Win98.
As posted previously, a work-around might be to record to the flash memory, then pull the card and read it with a card reader. Doesn't help with the built in 128MB memory though.
Posted on Mar 26, 2009
That's the work around.
I have the CD and driver but now Windows thinks it's an HP product and goes nuts.
Assigning it as a flash drive worked.
Posted on Apr 25, 2009
Driver win 7 64
Hi Fanis
They don't appear to do a 64-bit driver.
http://www.gigabyte.com/products/product-page.aspx?pid=1185&dl=1#
If you believe you have problems with the 32-bit driver. Use their support page or contact your supplier of the card.
http://esupport.gigabyte.com/Question/NonTech?country=
Feb 28, 2014 | Gigabyte GV-NX53128D GeForce PCX 5300...
Video card 5300 pcx geforce not wark with win 7 23/64 bit why
Widows has some compataility problems with some software and chose not to isupport some of the older cards. Gigabyte does show a driver for Win 7 32 bit here;
http://www.gigabyte.com/products/product-page.aspx?pid=1185&dl=1#driver
You can have Nvidia scan your system and see what they suggest. I couldn't find it in Legacy
http://www.nvidia.com/Download/index.aspx?lang=en-us
Good luck.
Apr 03, 2011 | Gigabyte GV-NX53128D GeForce PCX 5300...
I need a radio wiring digram color code for 2009 chevy silverado
2009 CHEVROLET SILVERADO C1500 4DR TRUCK WITH 4.3L ENGINE AND STANDARD AUDIO SYSTEM
Remote Start
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) IGNITION SWITCH HARNESS
LOW CURRENT, FOR HIGH CURRENT USE RED/BLACK AT VEHICLE FUSE BOX
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN (+) IGNITION SWITCH HARNESS
MAY BE YELLOW ON SOME MODELS
Accessory 2 PINK/BLACK (+) IGNTION SWITCH HARNESS
FOR REMOTE START INTEGRATION
Starter 1 YELLOW/BLACK (+) AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT
NOT FOR REMOTE START, FOR REMOTE START INFORMATION
Starter 2 PINK/BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type GM PASSKEY III® ANTI-THEFT SYSTEM
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense PINK (+) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/BLACK (AC) AT ECM MODULE UNDER HOOD ON DRIVER FENDER
BLACK PLUG PIN #57
Parking Lights LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH
Brake Lights LIGHT BLUE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
IGNITION MUST BE ON FOR THIS WIRE TO TEST
Reverse Lights DARK BLUE (+) AT BCM MODULE UNDER DRIVER DASH
Horn TAN (-) IN HARNESS AT STEERING COLUMN
ALSO AT BCM MODULE UNDER DRIVER DASH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock WHITE (-) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE UNLOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
PowerLock LIGHT BLUE (+) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE LOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
i would use a DLPK module
DLPK (2009 Chevrolet Silverado)
W2W
CC-Heated Seats Activation
DL-Arm Factory Security
DL-Disarm Factory Security
DL-Door Lock Control
DL-Door Unlock
DL-Driver Priority Unlock
PK-Immobilizer Bypass-Data No Key Req'd
RS-RAP Shut Down (Remote ACC Power)
RS-Tach / RPM Output
SS-Entry Monitoring ALL Door Pins
SS-Entry Monitoring Driver Door Pin
SS-Entry Monitoring Front Door Pins
SS-Entry Monitoring Hood Pin
D2D
CC-Heated Seats
DL-Door Unlock
Hope helps.
Mar 31, 2011 | Chevrolet Silverado 1500 Cars & Trucks
Sound driver for ga81915p duo
I need more data like which processor(socket or AM) etc so why dont you download it from
http://www.giga-byte.com/products/product-page.aspx?pid=1815&dl=1#dl
else get it from
http://www.drivercache.com/plus/search.php?keyword=GA81915P+DUO
enter the search term GA-81915P Duo in the search and download it.
Nov 15, 2010 | Computers & Internet
Can you connect a PoGo Polarioid printer to a computer for printing
I connect to my pogo via bluetooth with my laptop, To print a picture - Right click on the picture file and send to the bluetooth device.
I would love to see a rinter driver for it myself.
Dec 27, 2008 | Polaroid PoGo Digital Photo Printer
Drive program
I own the same MP3Player and have the driver CD.
Jul 22, 2008 | Nextway NMP-210R MP3 Player
Cannot record on +DL - Dual Layer Discs. Maybe it is the brand?
The discs could be the problem. Even in the same model you will find some that reject a certain type of disc, and yet the one made directly after it on the production line will be fine. The same applies to PC burners.
Other times those same discs will be rejected or accepted. It's all about the fine lines in production. A minor difference to things like the laser when it was assembled, or the dye used in the discs is all it takes.
This is why most companies will have a reccomended set of discs that are known to work due to them being manufactured to a higher standard. Between the higher and lower is not alot, but enough to cause problems.
Look for a place that sells discs as singles, then get one and try it out. The other thing to keep in mind is the more expensive discs will hold the data better, longer and with less errors.
Apr 16, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Need software v. 1.13
I've got the cd, could use yousendit.com to send you the drivers etc, it's 24mb. barrylevine(at)norwoodlight.com
Apr 08, 2007 | Pogo RipFlash Plus MP3 Player
Pogo RipFlash Plus MP3 Player Logo
1,557 people viewed this question
Top Pogo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pogo Audio Player and Recorder Expert? Answer questions, earn points and help others
