Question about Gateway 812GM PC Desktop
No monitor picture
I have not had the computer on for over a year and now I can get no info to go to the monitor
    Problem Solver:
  • 16 Answers
Try to hear the sound when pushing the power button,if there is no bip at all,open the case,remove the ram and clean it
Posted on Feb 19, 2012
Will not power on>>thanks for any info it's only 2 years old.
Two years is about right, look for bad caps as shown here:
http://s807.photobucket.com/albums/yy352/budm/GATEWAY/Gateway%20FPD2275W/
Use good caps with low ESR!
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 11, 2011 | Gateway FPD2275W LCD Monitor
Monitor problem
That usually means that there is a problem with the power supply specifically the backlight. If you connect the monitor to the computer with the computer running, shine a flashlight to the monitor and look if you can see an image on the screen. If you do, then the problem is with the backlight power supply. Typical problems are blown capacitor and/or transistors. I don't have any info about the circuitry of that particular monitor to be of more help.
Jun 30, 2010 | Soyo DYLM1788 Monitor
Samsung monitor loses picture
This is quite a typical problem, usually caused by defective electrolytic capacitors in the power supply of the monitor.
A good description of the phenomenon can be found here.
I'm afraid there's not much you can do, apart from having the monitor repaired - the defective capacitors need to be replaced.
Mar 28, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Picture will not display when computer is initiated. However, sometimes picture will appear but goes out within a minute and does not reappear. Blue power light is on, connections have been checked,...
Your monitor display is damaged. Normally 3 years warrenty so try to visit with your monitor in a company service center ASAP.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | ViewSonic VX2235WM Monitor
Turn it on get picture for 1 second then black
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm We also have a step by step dis-assembly and repair guide for the Westinghouse monitors posted there. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 26, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Monitor picture goes off after start-up
It sounds like you have a monitor with a common problem. After a few years some LCD monitors willblow a power supply. The problem is caused by parts called capacitorsoverheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm Youcan take the back cover off your monitor and look for the badparts,replace any that look like the pictures and your monitor shouldwork fine. The capacitors do need to be installed with the correct + and-connections, note the stripe on the old one and insert the new onethe same way. If you don't want to try the repair yourself we offer a repairservice for $35 plus shipping. If your problem is not the capacitorsthen it would be the backlights and that is much more difficult toreplace.
Buddy
Corporate Computer
www.ccl-la.com
Jul 09, 2009 | Norcent Technologies LM730 17" Flat Panel...
I have a LG L196WTQ-BF flatron screen. Computer powers up but screen does not turn on. I lhave used this for a couple of years with not problems.The computer I am using is a HP Pavilion a430n.
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jun 28, 2009 | LG L196WTQ Monitor
Optiquest Q19 monitor adjustment off
Finally found out that the Optquest monitor is an viewsonic brand monitor and finally downloaded the manual.
Jan 10, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Graphics
Hi, It could be the monitor itself that is failing, have you tried plugging in another monitor?
Other than that the recovery disc may not have had the exact drivers for your monitor so you may be able to get the drivers or display adapter drivers for that monitor and install them.
Let me know how you go,
SeaJade
Nov 28, 2007 | E-Machines eMachines Desktop PC
Gateway 812GM PC Desktop Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
