Question about Sentry Safe Fire-Safe Home/Office Safe
A3750 cannot get into safe type in correct code and the red error lights start blinking using factory default code as i have always used worked until today i put the key in turn it and then take it out then enter the code and the red error light starts blinking
3 Suggested Answers
chrischronic
  • 235 Answers
SOURCE: Error light comes on when keying combination code
Try new batterys ,also sometimes if too full ,you will have to hit it hard to get the stuff off the lock bars that keep them from moving .
Posted on Dec 17, 2008
  • 188 Answers
SOURCE: What is the factory code for the Sentry Safe Model A3750?
you have to contact sentrysafes.com for help with codes
Posted on Aug 07, 2009
Is my Power Supply or Other Board failing? TV Red Light Blinks 6 times always on failure
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 28, 2016 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
I cannot connect to the internet using my netgear n150 wireless router. The internet light is orange but the modem is working fine and I can connect to the router itself.
When the router is turned on, the Internet light turns amber for about 20 seconds and then turns green. If the light does not turn green, the router has a problem. If the Internet light is still amber 1 minute after turning on power to the router: a. The Internet is not accessible. Confirm that you have the correct internet setting. b. Clear the router's configuration to factory defaults. This will set the router's IP address to 192.168.1.1. c. Turn the power off and back on to see if the router recovers. If its still not working, reset to factory defaults. You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 4). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Jun 06, 2011 | Computers & Internet
How do I reset code on my gun vault GV2000
Enter the 1,2,3,4 factory number.
When the door opens, immediately press all 4 keys are once and release.
A red light will come on. then enter new code. lamp will turn off.
to confirm the new code enter it a second time.
red light blinks, an error has occurred or your timing was off, so just start over with the factory 1,2,3,4 code.
Nov 28, 2010 | Gunvault Multi Vault GV2000 Std
I dont know the pass code...?
the simplest way is by restoring the default configuration and then reconfigure the passcode.
You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function of the router (see “Erasing the Configuration” on page 6-7).
• Use the Default Reset button on the rear panel of the router. Use this method for cases when
the administration password or IP address is not known.
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
If the wireless router fails to restart or the power light continues to blink or turns solid amber,
the unit may be defective. If the error persists, you might have a hardware problem and should
contact technical support.
Dec 25, 2009 | NetGear WGR614 Wireless Router
Wireless light is not on
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot. If the wireless router fails to restart or the power light continues to blink or turns solid amber, the unit may be defective. If the error persists, you might have a hardware problem and should contact technical support.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Jul 14, 2009 | Sentry Fireproof Safe
Sentry Safe A3750 won't open new batteries
http://www.sentrysafe.com
call them
mj
Feb 22, 2009 | Home Security
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Dec 17, 2008 | Sentry Fireproof Safe
Sentry Safe Fire-Safe Home/Office Safe Logo
56 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
