Question about Garden
Have a skidder that will not come out of park
Have tryed park solinoid,park sensor switch,shifter unit
    Sergeant:
  • 316 Answers
Hello, i really don't know but i would check the trans,,
Posted on Feb 19, 2012
My acura tl 2003 is stuck in park
Your gearshift has a "solinoid" that keeps the gearshift in park until criteria is met..I.e. Brake is engaged, seatbelts etc. It's my guess you have an issue where that solinoid is not getting power or has gone def. If you have access to a test light, pop up the cover where the shifter is turn on the key step on brake and check power. If there is none your issue may be a bad brake or possible neutral safety switch. If you have power then the solinoid is the culprit.
Jan 09, 2015 | Acura Cars & Trucks
Shifter is stuck in park on 1997 honda accord
just press the brake pedal then shift the transmission not try to check the shifting lever remove the cover there is a electric solinoid connected to the brake pedal apply brake the solinoid innergize time to shift the lever if not change the solinoid
Jun 17, 2013 | Cars & Trucks
I have a 1995 Cutlass and when I push the brake, it won't shift out of park
Sounds like the solinoide on the shifter is not disengaging the lock so the shifter can be shifted out of park. The solinoide has likely gone bad.
Jul 25, 2011 | 1995 Oldsmobile Cutlass Supreme
My shifter got locked i hav a 2006 forenza
Most newer cars have a "shift interlock" on them so you can't shift out of PARK unless you are pressing the brake pedal. It is usually a switch attatched to the brake pedal under the dash. If this switch goes bad, you won't be able to shift out of PARK.
Dec 30, 2010 | 2006 Suzuki Forenza
1992 Toyota Camry won't crank
Check the ground cable going from the battery to
alternator, then to chassis. Make sure there is no
rust at the chassis ground wire terminal, and that it
is very tight. The fusible link will be off the alternator
red power cable,usually, but not 100% on that car.
Good luck.
Mar 30, 2010 | 1992 Toyota Camry V6
No noise when i turn key battery is fine where is
on most fords the solinoid is mounted under hood on passenger side. follow battery cable to solinoid, to test solinoid, put a jumper accross the neg, and pos, terminals on solinoid. if the car starts, then the solinoid is bad.if not check cables to starter. hope this helps toolman,
Feb 15, 2010 | 1998 Ford Windstar
Cannot shift the trans out of park. Is there som sort of brake pedal interlock (solinoid or whatever)?????
There is a lock out solinoid in the steering column. but the problem was in the shift cable.
The easiest way to diagnoise this problem was to disconect at the transmission and then try the shifter.
Jun 16, 2009 | 1996 Honda Odyssey
Will not shift out of park
can you move the shifter and it wont go into gear or will the shifter not move at all?? if shifter wont move, there is an electrical solinoid that will not allow the shifter to release when the car is off, that could be faulty, i think it also has a safety mechanism that wont allow it to shift if your foot is not on the brake? if the shifter moves through prn321 but the trans wont come out of park, you have broken the shifter cableand or damaged the shifter mechanism in the trans. hope i have been of some assistance
May 16, 2009 | Hyundai Motor 2003 Elantra
97 mustang won't come out of park,brake lights coming on and I replaced it anyway can it be the ignition switch or is there a solinoid that releases the cable to the shifter button ? Thanks
Is the steering wheel turned? If so this would cause the shifter to stay in Park and not come out. Turn wheel as far as it will go and turn key on put foot on brake and tire. If not the neutral park swith on trans might be bad.
Apr 22, 2009 | 1998 Ford Mustang
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
