Question about Euro-Pro S3325 Handheld Steam Vacuum
I can't get my shark steam blaster model EP95 to create steam?
I have shark steam blaster steam cleaner and I haven't used it in several months. I wanted to clean with it and as usual I put water in and waited for the steam to create and ready light never came on. I left it on for 15 minutes still no steam. I can't find my manual for it and tried to find it online and the company could even fin the manual online.
  • 1 more comment
  • romeomls Jan 14, 2009
    Please help me if you can, I have a new Euro-Pro X and can not get steam to come out. I conected everything up like the directions said but there is no steam coming out. I know the water is steaming hot because I attempted to turn the top where you put the water and solution in and it was hot as a radiator. It just that nothing is coming through the steam vacuum hose. Please respond you have a solution...
  • pitbulldefen Feb 18, 2009
    Please someone help me out with this problem. I own the shark model # S3325 and can not get the steam to come out of the hose even though the heater is working fine. It heats up just will not release steam.
  • jacinpdx Mar 21, 2009
    It worked great the first time I used it (about two weeks ago). Now it just sits there trying to get hot. UGH!!!
    New Friend:
Pull the (3) coasters/feet out and unscrew the 3 screws. take off the one end of the steam"boiler" (two clamps). tilt open end up and pour white vinegar [carefully] in there, prop up so it does not fall over, and soak overnight. dump out lime and water scale and rinse out a couple of times. Be very careful to not get water on electrical parts.
Take an air pig and blow out the line (Black) from where you disattached it to where the steam comes out [at the handle]. Be sure to mark electrical connections [4 on one, 2 on the other] so you don't blow a breaker switch like I did.
Posted on Dec 12, 2012
I had the same problem it was just built up calcium take the screws off at handle then you will see the hose were the water comes out there will be a plastic pice connected and a metal ring holding the two together pull the metal ring down and pull the rubber hose from the plactic pice now make sure that plastic pice is clear then VERY carfuly take a meltal hanger dowm the rubber tube you might feel it hit something if it does twist it back and forth now if you think you broke it all up fill the steam with water make sure pump switch is on and water should shoot out if it works put it all back together and try it againg i truly hope this helps
Posted on Mar 13, 2016
If you decide to junk it, I'll buy it just to get the resevoir lid that I lost
Merlyn
Posted on Sep 01, 2009
Does not steam when press button
Most probably thermal fuse burned. Which one ison the hand unit. If it s good check the selonid and the switch with cables.
Feb 25, 2016 | Shark Ultra Steam-blaster Hard Surface...
Where can I purchase a safety filler cap?
See Google.
[PDF]steam cleaner - Pdfstream.manualsonline.com
pdfstream.manualsonline.com/.../e7f63cef-798e-41f3-bec7-5e43d5da5d...
When using your Steam Cleaner basic safety precautions should always be ... not screw the safety/filler cap onto the .... When using the Ultra Steam Shark II with.
Sep 29, 2015 | Shark Ultra Steam-blaster Hard Surface...
A how to fix it shark steam blaster EP95 manual
Hey, this is Jeremy with Crucial Vacuum,
I'm sorry to hear you are having issues with your shark steam blaster vacuum. I have provided you with the manual for you vacuum below.
http://www.manualslib.com/manual/49659/Euro-Pro-Steam-Blaster-Ep95b.html?page=3#manual
You can purchase replacement parts for Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Carehttp://www.crucialvacuum.com
Aug 04, 2015 | Shark Vacuums
My steam mop does not make steam.
how do you get a shark steam cleaner unclogged?
Jun 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
After accidently leaving shark steam mop (not the pocket one) with water in the tank several months.....when I tried to use it recently, it would not steam even after emptying out old water and...
No, the shark tech support is on the manuals link....
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Where can I get spares for a Euro pro Shark steam blaster model s3300
Check the manuals link....
heatman101
Nov 04, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Replacement parts
You can found them on amazon, take a look here: Amazon com Euro Pro S3325. I hope this was helpful. Cheers
Feb 17, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Euro-Pro S3325 Handheld Steam Vacuum Logo
1,589 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
