Question about Samsung SCH-u740 Cellular Phone
NAM2 locked. I have a Samsung SCH-u740 and I recently switched it from NAM1 to NAM2, and when the phone powered off and turned back on, it was locked and my new lock code I entered would not work nor would the last four digits of my phone number nor would 0000. How do I fix this?
  • 3 more comments
  • agever6443 Jan 04, 2009
    i have the same problem, i tried 4043 and it didnt work
  • Anonymous Apr 27, 2009
    wont become unlocked
  • Anonymous May 15, 2009
    What are NAM1 &NAM2 ?
  • animalfreak May 11, 2010
    I entered 228 and it won't let me? it says private call something something..
  • agever6443 May 11, 2010
    thanks so much
Http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=22&AT_ID=87077&ARS_ID=9833651
its in the samsung frequently asked questions. All you do is go to windows calculater turn it to HEX enter the hex number under your batery switch the calculator to dec and the last 4 numbers is the NAM2 code
Posted on May 10, 2009
  • godb Apr 12, 2011
    Thank you so much. I called Samsung customer service and they told me to go to the Verizon store and that they would have the equipment that would be needed to unlock my phone from NAM2. The store told me to call Samsung customer service. Ohhhh what a big help they were not. I did what you described and it worked without my having to reprogram the phone. Thank You
    Problem Solver:
  • 3 Answers
Hey!! My phone got switched to nam 2 lastnight and I fixed it today!!! All I did was call 1-888-987-4357 they ask for a hex # which is on the back of ur phone and your information like where u live and stuff and they put u on hold for a while so be patient bc after u get off hold they will ask u to enter codes and one of them they give u will work and there ya go lol ur phone can be used again (hey!! If u have already had this happen before and u had to call customer service for a code it will not work the second time) so if u see anybody else with this problem let them know this
Posted on Jan 05, 2009
This worked for me - Call #228, and it'll start reprogramming your phone. Just let it do that, and then the phone will restart... And when it starts again enter the last four digits of your phone number as the password, it should unlock. Then, I'd suggest going and changing back to NAM 1! =)
Posted on Nov 10, 2008
This worked for me - Call #228.... It'll start programming your phone. Just let it program it and let your phone restart. When it restarts the password should be the last four numbers of your phone number... And then I'd suggest going in and changing back to NAM 1! =)
I did it i called samsung the code is 4043 d best man i am so happy hope this works if not call samsung
Posted on Dec 31, 2008
I put my phone on the nam2 settings and now i cant unlock the phone
Hi Ericmark197 lisren to unlock your phone try the last for numbers of your phone number. Then you should be able to switch the phone back to nam1
Nov 25, 2010 | Samsung SCH-u340 Cellular Phone
Switched to NAM2 and do not know the lock code.
Dial *22899 and press SEND to program the phone.
after it has finished downloading the programming information, the phone will reset.
The Lock code will now be set to the last 4 digits of your phone number.
when you have finished, be sure to switch back to NAM1 and dial *22899 again to re-program it.
Sep 30, 2009 | Samsung SCH-u740 Cellular Phone
Stupid code
If you can switch to nam1, that is your active phone number. If its asking for the code first the code will be 000000 or 0000
Jul 31, 2009 | Samsung SCH-u740 Cellular Phone
Initial programming needed
Dial *228 and press send. Listen for the prompt and press 1 to program your phone. Remain on the call while your phone is programmed (could take up to 2 minutes). Do not hang up until you hear, 'Your phone has been programmed successfully."
Apr 22, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Locked and cant get in
try the last 4 digits or ur number orr! 0000
Apr 14, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Cant unlock my phone
If you know your original lock code, take it in to your service provider, each code is diffrent and can only be programed manually, if you dont know your original lock code you will have to sacrific all info pics,mess,numbers, etc. by a reset... I can guide you through the steps to erase all if you lost your Unlock code, or switch back to nam1 if you know your lock code, ( when you switch back, if security is on automatic lock, password is required) intial programing code is not your Unlock code.
Apr 03, 2008 | Samsung SPH-M500 Cellular Phone
Network busy/error 2048
I had the same problem with my old phone the Samsung A660. After 45 minutes on phone with Bell Mobility tech support (which did nothing to cure the problem) I fiddled around with the settings abit, and found there is a setting for something called NAM1 and NAM2. I changed it to NAM1 and I was able to access the browser again! I'm not sure though if the U740 has this NAM1 and NAM2 setting. This what to did for the A660:
  • Press MENU
  • Scroll to (7) SETTINGS, Press OK
  • Scroll to (8) OTHERS, Press OK
  • Scroll to (5) SET NAM
  • Press OK
    Options:
    NAM 1
    NAM 2
  • Scroll to option, Press OK to set
Oct 08, 2007 | Samsung SCH-u740 Cellular Phone
Samsung SCH-u740 Cellular Phone Logo
744 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
