Question about Dell Inspiron 537 ST PC Desktop
2 quick beep codes
When I power up, I get nothing but 2 quick beep codes. I've R & R the ram--to no avail. Then I removed the extra video card and plugged the monitor into the built in card. I still get 2 real quick beeps.
    Top Expert:
  • Dell Master
  • 2,907 Answers
You're right about 2 beeps means "No RAM Detected"
Maybe re-check the RAM chips for bad connections or broken pin.
Also you could measure DC power to the RAM connectors.
Hope this helps.
Posted on Jan 31, 2015
  • 121 Answers
SOURCE: dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Posted on Feb 21, 2008
SOURCE: Dell Precision Workstation 670 has no video on screen.
Find the owner's manual:
http://support.dell.com/support/edocs/systems/ws670/en/index.htm
There you will find a table of beep codes and what they mean.
Posted on Aug 17, 2008
freetek
  • 5568 Answers
SOURCE: emachines single beep
It may be necessary to enter the BIOS setup to disable the integrated video and/or turn on the PCI slot(s).
It varies but entering the BIOS setup uses one or more keys (sometimes Esc, sometimes F1) that are pressed right after power on. Check your user guide to see which key give you access.
Most systems aren't smart enough to do that on their own and you may have the system looking at two video processors at the same time and is unable to resolve the conflict.
Posted on Jan 14, 2009
sparky1500
  • 1066 Answers
SOURCE: Dell XPS 700 Black Screen, No Bios, Post error 1 2 3.
could be the cpu, its prolly the only thing you havent tested. or the power supply.
Posted on Mar 11, 2009
  • 90 Answers
SOURCE: won't boot..getting 2 short beep codes..have tried memory that i know is good.
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Posted on Apr 20, 2009
The yellow light comes on inside but the computer won't come on neither does it beep?
First remove any power cables and batteries(if laptop) from your system and hold down the power button for 15 seconds.
Plug the power cable back in & attempt to boot.
If this does not solve your problem then you will need to remove all non-essentials from your system.
If laptop, this simply consist of battery, ram, optical drive & any other removable bays or devices. Unplug all cables except the power cable & attempt to boot.
If desktop, you will need to remove any cables plugged into your computer except keyboard, mouse, power, video, sound, & network cable. Open the case & remove any PCI cards, except video cards, unless you have on-board video, unplug the data & power cables going to the optical & hard drives. Now attempt to boot. If you have no luck you can remove your RAM sticks & try again. If you get an error beep warning you about no ram then you might have a bad ram stick. If none of the above works then you may have a bad power supply or motherboard. Power supplies are pretty easy to test with tester or use a spare.
Jul 16, 2012 | Dell Computers & Internet
Video Card won't work, just beeps.
This model video card requires 1Gb of system RAM for it to oerate properly.
Check your RAM modules they maybe faulty.
The specs for this graphics card are on this WEB site.
http://www.amd.com/la/products/desktop/graphics/ati-radeon-hd-2000/hd-2600-pro/Pages/ati-radeon-hd-2600-pro-specs.aspx
Mar 06, 2012 | Computers & Internet
I turn the pc on nd the motherboard beeps like an alarm. I've pulled everycard out, ram, cpu etc and just left the fans plugged in, but the problem still persists.
The beeps are the clue to what is wrong: Count the beeps and check against beep codes like at http://www.computerhope.com/beep.htm
Check that *********** board is listed, some use slightly different codes...
Aug 07, 2011 | Abit IN9 32X-MAX Motherboard
Continuous short beep when start... no boot up, already change the power supply and few rams for testing, but no change. should the motherborad or cpu fail?
processor failure does not produce beeping sounds, are you sure that your extra rams are working? try to change the video card if you have the removable one. then if you're using the built in video card, try removing the sound card and modem cards or lan cards.beeping sounds is only for ram errors and any other hardware but not limited to motherboards. by the way try to clean the slot for rams, video cards and others. this would help.
Jul 12, 2011 | Acer Computers & Internet
When i power ON my dell mini it beep 8 time Please kindly hrlp
The POST beep code - 8 beeps indicates a memory problem.
Try reseating the RAM modules to ensure proper connection.
If it still does not boot up, the RAM may be faulty. Remove the RAM and take it to your computer repair shop and get them to test the RAM for you. If faulty the RAM needs to be replaced.
Jun 15, 2011 | Dell Inspiron Mini 1012 Netbook...
Satellite x205-sli1 will not boot black screen error beep 1long 2 short please help. Powers up good and reseated ram nothing.
Thank you for sharing the beep code. It means that its a problem with the Video Card and Video Cards are usually buit-in to the Motherboard for laptops. The only way to fix it to replace the Motherboard in order to get the new Video Card. Hope I've helped you somehow.
AnEspera
Apr 24, 2011 | Toshiba Satellite M65-S809 Notebook
No ram beep comes without ram and no display
> No RAM beep comes without RAM.
That is to be expected -- when the motherboard does _NOT_ detect any properly-mounted RAM, the motherboard sounds the "no-RAM" beep.
> and no display
Correct. Without RAM, the computer cannot "paint" anything onto the video screen.
Nov 06, 2010 | Intel D845GVSR Motherboard
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
Motherboard will not post
Turn it off. Remove the AC power-cord.
Disconnect all the devices (floppy, disk-drive, CD-drive).
Remove any add-on PCI cards (modem, network, TV, 2nd video).
Remove ALL the RAM.
Reconnect the power, and turn it on.
Try to POST -- if it is not "dead", it should "beep" a few times, due to having _NO_ RAM installed.
Turn it off.
Add ONE stick of RAM.
Connect the AC power-cord.
Turn it on.
Same "beeps"? Different? No beeps?
Oct 09, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Won't boot
Turn it off.
Disconnect the AC power-cord.
Disconnect all the devices (floppy, disk-drive, CD-ROM).
Remove all "extra"add-on cards (modem, network, TV, 2nd video).
Remove all the RAM.
Turn it on.
Does it "beep", to complain that _NO_ RAM is available?
If not, the motherboard is "dead".
Oct 08, 2009 | Compaq Armada M700 Motherboard
Dell Inspiron 537 ST   PC Desktop Logo
133 people viewed this question
Alun Cox
