How do i get the ethernet controller bak without a disc ??
  • 32,281 Answers
If the network controller is built-in on the laptop then you can download it from the laptop's manufacturer WEB site.
Since you did not provide the make and model of your laptop I cannot direct you to that WEB site.
Posted on Feb 20, 2012
What does it mean when the main screen reads: The User Service service failed login.
You need to login to your computer in Safemode and Follow these steps:
  1. Click Start, type regedit in the Search box, and then press ENTER.
  2. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
  3. In the navigation pane, locate the folder that begins with S-1-5 (SID key) followed by a long number.
  4. Click each S-1-5 folder, locate the ProfileImagePath entry in the details pane, and then double-click to make sure that this is the user account profile that has the error.
    • If you have two folders starting with S-1-5 followed by some long numbers and one of them ended with .bak, you have to rename the .bak folder. To do this, follow these steps:
      1. Right-click the folder without .bak, and then click Rename. Type .ba, and then press ENTER.
      2. Right-click the folder that is named .bak, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
      3. Right-click the folder that is named .ba, and then click Rename. Change the .ba to .bak at the end of the folder name, and then press ENTER.
    • If you have only one folder starting with S-1-5 that is followed by long numbers and ends with .bak. Right-click the folder, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
  5. Click the folder without .bak in the details pane, double-click RefCount, type 0, and then click OK.
  7. Click the folder without .bak, in the details pane, double-click State, type 0, and then click OK.
  8. Close Registry Editor.
  9. Restart the computer.
  10. Log on again with your account.
Jul 31, 2014 | Sony VAIO Computers & Internet
Don't have disc for ethernet controller on motherboard daoat8mb8h6,rev h
You can download the LAN and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Sep 02, 2012 | HP Computers & Internet
How do i get ethernet controller bak without disc?
You can download the driver from the manufacture website
Feb 19, 2012 | Computers & Internet
Ethernet controller for msi k9n6sgm-v
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
May 25, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
KV8-X motherboard. I have a network card installed, but I keep getting new hardware found for ethernet. I try to disable the ethernet card via system. I can't connect to internet.
hope this helps
Apr 26, 2011 | AMD ASUS K8V-X (MBASUSK8VX) Motherboard
Dog eat the disc
I'm guessing your trying to say the dog ate the disc that came with your Retractable Ethernet Cable? You're fine. It's just an ethernet cable, you can use them without the disc.
Mar 21, 2010 | Micro Innovations (CPQ06EPC) 6ft Auto...
Ethernet controller didn't work
Have you checked your drivers?
Go to control panel - system - device manager
Or control panel - type in device manager (depending on your os)
If there is a question mark beside your ethernet controller than you need to update the driver. If you have the disc pop it in the computer and then right click the ethernet controller and click update driver and then follow the wizard through and that should fix it if the driver isn't there.
If you haven't got the disc you will need to download the driver from the manufacturers site.
Feb 05, 2010 | Dell Latitude D600 Notebook
Laptop wont read discs
i had the same problem and posted it on this site to what might work is this:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this
CREDITS GO TO CRICHNER for helping me out on this one!!
let me know if it helped.
greetings
Jan 02, 2009 | Computers & Internet
Satellite A205 help "loading DVD"
Have you tried other discs? Does it read CD or recognize blank discs? Have you tried a bootable disc to see if it reads prior to Windows loading?
If the drive doesn't appear in My Computer this is a possible fix:
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 19, 2008 | Toshiba Computers & Internet
Vostro laptop dvd/cd player not seen by system.
1.go to bios by pressing f2 key on dell logo
set num lock caps lock scroll lock on
press alt + e
press alt + f
press esc twice
2.
Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Step 4: Restart the computer loadTOCNode(3, 'resolution');
Mar 14, 2008 | Dell DVD-rom DVD Drive
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
