Question about Philips 43PP9202 43" Rear Projection Television
Color control module
Where can I get a color control module for a phillips magnavox model 43PP9202. The part number for the module is sanyo 54945198
    Genius:
  • 2,920 Answers
Try phillips.com/parts
Posted on Oct 26, 2008
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
Can't find manual for Phillips Universal remote. Need codes for LG TV
what is the your phillips remote model number? Model number is located under the batteries. then go to www.p4c.philips.com to get the codes...hope this helps
Jan 06, 2012 | Philips Magnavox Learning Universal Remote
Sanyo and tv remote problems
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philips
If you know the model of your Phillips remote, you should be able to fihd it here, download the file, then unzip user guide. Hope this helps.
Aug 18, 2009 | Philips Magnavox Learning Universal Remote
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Adjusting to the proper color
Tint would be the control that will control the color balance, but this sounds like it may be deeper then that. Turn your color all the way down so that you have a black and whit picture. If the picture is still yellow then you have a problem with the blue picture tube.
Feb 02, 2009 | Philips 43PP9202 43" Rear Projection...
Need codes for phillips universal remote
The codes I have for the Sanyo TV are:... 002, 412, 506, 619, 902
for the Magnavox DVD player they are:.... 441, 442
Jan 03, 2009 | Philips Magnavox Learning Universal Remote
42 in. Phillips, model #43pp920217
Yes...Change them both.....use first quality only ...I use the best
and it is an upgrade....STK392-110 sub to STK394-160E = part
# CZ 01341 ( Hitachi made by Sanyo) cost about 30.00 ea.
Be sure to verify your part # before ordering any parts.....
Also,check B+ resistors for damage....located next to IC's......T.
Jan 03, 2008 | Philips 43PP9202 43" Rear Projection...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Help tv comes on and goes right back off
A common problem with this model is the convergence IC's on the small signal module going bad and keeping the set from staying on due to protective shutdown circuits used. If that is your problem, the easiest fix would be to replace the module - Philips Part #313503710091, about $200 or so, or have a technican replace both IC's Stk392-120, Philips Part #932212344682 about $45.00 each plus labor and service charge of course. Other parts could be bad, but this is likely what I would try first.
Feb 09, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
