Question about Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In
Manual for Hilti TE5A rotary hammer - Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In
  • donalddykes3
    donalddykes3 Feb 19, 2012
    Bought used Hilti TE5A rotary hammer --would like to find a service manual and or a parts manual. "E" mail donalddykes31@yahoo.com
  • 2,176 Answers
I would suggest calling them direct at 1-800-879-8000 and asking them to send one as a PDF file to you. We are not allowed to contact you direct.
Posted on Mar 01, 2012
rowdy45176
  • 2176 Answers
SOURCE: I cant seem to locate a Hilti TE5A battery charger
I would call Hilti direct at 1-800-879-8000 and speak with one of their customer service reps and they should be able to help. If not let me know and I will contact my local sales rep and see what I can do for you.
Posted on May 21, 2009
rowdy45176
  • 2176 Answers
This must be an older tool but you can try calling 1-800-879-8000 and ask Hilti direct where you can purchase this if it is still available. Good luck
Posted on May 23, 2009
  • 123 Answers
SOURCE: Hilti TE 17 Rotary Hammer repair switch fix
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Posted on Oct 29, 2009
Testimonial: "worked well for me"
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
  • 123 Answers
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Posted on Jul 23, 2010
TE54s manual oil volume
Try https://www.hilti.co.uk/holuk/page/module/home/home_main.jsf?lang=en
Jun 25, 2012 | Hilti TE 7-C 120V Rotary Hammer Drill
I am trying to find a trigger switch for a Hilti TE72 can you help? thanks colin.
Hilti only sells parts directly...
http://www.us.hilti.com/holus/
heatman101
May 14, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
How to use hammmerdrill
Call Hilti at 1-800-879-8000 or try their website at Hilti.com for an operators manual. Let me know if any problems.
Aug 31, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
Te70 hilti hammer drill
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Te-5 rotary hammer i need parts
Call Hilti direct at 1-800-879-8000 and speak to them. They can fax or ssend you a breakdown of the tool list. They will also sell you parts. I don't know of an outside source for Hilti parts. If I have helped you would you please rate my response accordingly and Thank you.
Aug 23, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
May 11, 2009 | Hilti Cordless Hammer Drill Sfh 151 A...
May 11, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti Hammer Drill 76p atc wont spin, has flashing led
Sounds like it needs new brushes. Schematics can be found on hilti.com. tech support - rotary hammers/ combi. Look up model number. Some of the older stuff is obsolete. Should find info there.Please rate me
Apr 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In Logo
274 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
