Connection of PS3
We are trying to connect our sons PS3 to his new Samsung tv, have connected the HDMI cable to PS3 and TV but still not recognising it, can someone help rather frustrated 13 year old waiting to play on his PS3
  • 2 more comments
  • vickers43 Oct 26, 2008
    Thanks for speedy response, but can't check menu as can't get it to show on tv.
  • san565 Dec 05, 2008
    I have tried this method with no sucess I took the ps3 back to shop for check up and it was fine. ?
  • Anonymous May 15, 2009
    well its the same problem as thee 13 y/o but ours is a sharp aquos tv... we connect it with an hdmi cable or rca cable but neither works... dvd players work though, with both cables...
  • Any Guy
    Any Guy May 11, 2010
    Check the menu on the PS3, I believe you will find a setting in the menu to turn on the HDMI output.
  • 320 Answers
You will have to connect it to the TV using the composite cable to change the settings. This is the cable with yellow red and white connectors. Connect it to one of the composite inputs on the TV. You should be able to leave to HDMI connected at the same time so that once you make the change, you can change to the HDMI input and see if it works.
Posted on Oct 26, 2008
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
Pioneer vsx521 stopped recognising hdmi connection from computer
Press the Audio Parameter button (Looks like an x) then scroll up until you see 'HDMI AMP' and hit over to the left or right so it shows 'HDMI THRU' the HDMI will redo the handshake and you should have sound.
Mar 12, 2017 | Pioneer Audio Players & Recorders
I have a Samsung LW32A33W and it worked fine using HDMI cable for connecting a PS3. Suddenly when I connect my PS3 with the TV using the same cable I get a blue screen and nothing happens. Any ideas?
That HDMI connection hub port it some how got short and it dead.Tries other HDMI connections hubs.If all are like that they are all dead.All HDMI hubs ports connections are link together.If one dies usually all HDMI hubs dies together.Than ur tv Tuner signal board will not have anymore HDMI hubs functions connections at all,none of the HDMI hubs will work again ever.Have happen to mine Samung tv,so now i have to stop using HDMI hubs all together.
Aug 12, 2011 | Samsung LW32A33W 32 in. HD-Ready LCD...
No Input Signal when PS3 is connected to TV
go to your video sttings in the XMB and make sure HDMI is selected as the connection type
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection works but not std rca AV
You must set it OFF HDMI while connected to the TV...
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
I have a new ps3 slimline,cant get a connection t my samsung HDTV
What you need to do is use a different tv or scart/av cable first, go to settings and reduce the resolution its because the tv cannot handle such a high res, if this dosent work, please post back, Regards
Dec 25, 2009 | Sony Playstation 3 (PS3) Console
Connection error from ps3 to tv.
When you hit the power button from the console, hod it until it beeps at you twice and it will reset the video settings. I read this on a post from gamespot. I hope it works.
Jul 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
308 people viewed this question
Top Televison & Video Experts
Electro Med Services...
