Question about Black & Decker Saws
How to change the blade on a black and decker table saw
  • 2,176 Answers
Unplug tool first. remove the throat plate and raise the blade all the way up. There were 2 wrenches included with this saw when new,, an open end wrench about 3/4" and a box wrench. Hold the spindle with the open end wrench and loosen the hex nut with the other one. It is a standard thread.
Posted on Feb 21, 2012
2 Suggested Answers
  • 643 Answers
SOURCE: black & decker 10" table saw -where is the blade
The Blade is held on by A Nut and Washers. Remove the Blade insert and you should see the nut and washer
Posted on Jun 26, 2011
How do I get the blade on my new Black and Decker 15 amp table saw to be at 90 degrees? I have the angle device at the zero mark and the blade is still at a slight angle. Is there any adjustment tha
I had a similar problem with my Ryobi table saw. I got out my square to establish true vertical, then tapped the motor housing lightly with a rubber mallet until the blade was at true vertical.
(sometime a hammer is the appropriate tool.....)
Oct 10, 2014 | Black & Decker BDTS200 15-Amp Table Saw...
Need to replace a miter saw blade on Black & Decker saw
If you don't have a manual, you can contact Dewalt, and they will get you one or help you. UNPLUG THE SAW!! , if your saw has a blade lock, engage it, if it doesn't hold the saw firmly on a scrap piece of wood. Then use the correct wrench and loosen the retaining nut. Take the nut off, remove the blade
Feb 24, 2014 | Black & Decker Saws
Where is the serial number on my black and decker table saw
You would be looking for the Model number, not the Serial number. I don't know if that will help you find the right manual. But here's something else -- a table saw is an essential woodworking tool, but without some basic instruction can be VERY dangerous. There are many sources of information about how to safely use a table saw that would all serve your son even better than having the specific user manual. There really is not all that much difference between the basic operation of any of the consumer marketed table-saws anyway.
Oct 09, 2012 | Black & Decker Saws
I lost the blade change wrench for fire storm 10 inch table saw,cant find a tool that will fit
probabbly have to order off line. or sears hardware may carry them. or a speciality woodworker store.
Jul 08, 2011 | Black & Decker 10-in Firestorm Table Saw...
Black & decker 10" table saw -where is the blade
Jun 26, 2011 | Black & Decker Saws
How to change the blade? We have one wrench, but you need two correct? Where can I buy the wrench if I need one?
Well I use a wrench on the bolt and a screw driver in the teeth against
the table to stop the blade from turning.
You could also use a vise-grip to hold the blade, just be careful if you have carbide teeth so you don't break one.
Some saws have a blade lock on the motor, I don't know about yours.
I find it best to lower the blade so its just above the table so it can be held, and the bolt is out of the way of the table.
Feb 11, 2010 | Black & Decker BDTS200 15-Amp Table Saw...
My black & decker band saw is making a noise behind the table and throwing off the blade. How do I fix this ?
Open the case and look for stray wood pieces. Check the bearings for both wheels. Check the mounting of the lower wheel to it's shaft. Operate the saw by hand until the problem is fixed. Good luck!
Jan 10, 2010 | Black & Decker BDBS100 9-Inch 3.5-Amp Band...
I need to know how to change the blade on a Black and Decker 1710 Type 2 10'' Miter Saw.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in the model number 1710 and it will go to another page requesting either a breakdown or instruction manual, you have to use the manual for a type 4. They do not offer the type 2 as an online version. Hope this helps
Mar 30, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Table saw blade wabbles alot when cutting?
This could be caused by several problems. First unplug the saw. Put a known straight edge against the blade (making sure not to contact the teeth) turn the blade slowly and watch for runout. Second make sure the spacers and blade flanges are on correctly. I would just about think it would be the blade. If you provide the model and brand I can do some more research. Good Luck
Jan 03, 2009 | Black & Decker DEWALT 12 In. 80 Tooth Thin...
When I try to change the blade on my table saw the shaft moves when I try to loosen the arbor nut. I am blocking the saw blade from moving
If it is like a Dewalt table saw it requires 2 wrenches, one for the hex nut and the other open end for the spindle shaft. If this doesn't help you can go to their website and look at an operators manual for this particular tool.
Dec 09, 2008 | Black & Decker BDTS200 15-Amp Table Saw...
Saws Logo
361 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
