Question about Garden
I need a service manual for a Blanchard no. 18 grinder
I need to make adjustments to the gibs
  • shammapetey
    shammapetey Feb 21, 2012
    I'm sorry I had problems trying to post my request for the blanchard manual, so I left out the "free Download" part of my request. The actual problem is not finding the manual, The problem is finding one for free.as I don't want to spend up to $100 for a book on a machine that I don't own. Ask.com says there are free manuals on this site so that is why I am here.
    Sergeant:
  • 316 Answers
Blanchard No. 18 Grinder Combo Manual ' eBay
hello, here is your manual,hope this helps,,
Posted on Feb 19, 2012
  • shammapetey
    thank you for finding that manual
How do i level jointer tables to make them co-planer
I assume you mean that the two tables are not in parallel planes. No, I don't think adjusting the gibs is going to buy you anything unless they are so loose that the tables don't seat flat on the ways. If this is a very old jointer, and the ways are worn so they are no longer flat, then might have to regrind them - but that would be difficult. I would measure the amount of "out of parallel" that the tables are at different depth setting after tightening the gibs so that the tables are just a little harder to move. If they are out of paralell by the same amount at different table heights, then I would put the whole jointer (not the base of course) on a surface grinder and grind both table tops. Of course you would need a pretty big surface grinder, depending on the size of your jointer. Good luck!
Jul 20, 2012 | Masonry Tools
Can I level the infeed and outfeed tables on my 6" Ridgid planer/jointer? I don't see such information in the manual.
The majority of jointers even cheap chinese imports have 3" or 4" hand cranks for both infeed and outfeed adjustments. The gibs can usually be adjusted when needed even on cheap jointer planers.
The rigid website has a support page and product parts and manual download.
If the download doesnt work call them and insist that they e-mail or mail a paper copy.
Most jointer planers are somewhat similiar in design and appearance.
Some power tool instruction manuals from competitors may have more complete step by step instructions.
Jan 20, 2011 | Ridgid Masonry Tools
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My cuisinart cbm-18 does not grind at below a 10 setting?
Hello, and thanks for using FixYa.
I'm guessing the problem is that the grinders blades, or the parts that do the grinding have become somewhat dull, (opposite from Sharp.) and no longer can get to the beans like it used to.
Cleaning the machine properly might improve its performance.
CLEANING/MAINTENANCE INSTRUCTIONS
1. Be sure plug has been removed from outlet.
2. Beans can be removed from the hopper by lifting off the lid and pouring excess beans out. Hold down the Manual button to cleanout any remaining beans.
3. The bean hopper, bean hopper lid, grind chamber, and grind chamber lid can be washed by hand with hot, soapy water or placed in the top shelf of a dishwasher. Dry thoroughly.
a. Remove the bean hopper by rotating counter-clockwise bringing the selector past grind setting 18, align the arrows and lift up. Make sure the hopper is empty.
b. Remove grind chamber by pulling toward you.
4. Remove the burr grinder, once the bean hopper has been removed, by grasping the metal handle and lifting up. Use the brush to remove grinds or wash by hand. Replace the burr grinder onto the unit and rotate until the piece is fully inserted. Push handle down and replace hopper.
NOTE: The hopper will not attach to the unit if the grinder has not been fully inserted.
5. Wipe body of grinder with a damp cloth.
6. Any other servicing or maintenance should be performed by an authorized service representative.
WARNING: NEvER ImmERSE UNIT IN WATER
Oct 14, 2010 | Cuisinart CBM18 Electric Grinder
How to use the astra coffee espresso
Hello there:
here is a couple of links that will help you get the right manual that you need ok?
best regards michael
  1. CoffeeGeek - Espresso: Espresso Machines, Astra Boiler Level Control ... i got the user manual, and a parts list from Astra, and am attempting to ... Expertise: I love coffee. Espresso: LM GS3. Grinder: Mazzer. Vac Pot: have one. Drip: no ...www.coffeegeek.com/forums/espresso/machines/407128 - Cached
  2. CoffeeGeek - Espresso: Espresso Machines, need help understanding my ... Astra recommends a particular type in their user manual, but there are better ... Expertise: I love coffee. Espresso: Astra Pro. Grinder: Macap M4 & Digital M4, BV ...coffeegeek.com/forums/espresso/machines/378621 - Cached
  3. Espresso Grinders Coffee machines, Grinders,parts, Slush machines ... HGS007 Astra home espresso grinder with timer for direct ... MDF manual. MDF Exploded diagram. Virtuoso Conical Burrs Espresso Grinder. Virtuoso user's manual ...saecoparts.com/EspressoGrinders.html - 235k - Cached
  4. Astra Espresso Machines Espresso machines, Grinders, parts, Slush ... Astra Mega III Manual rocker switch dosing 220V 5500 Watts 18 liter boiler ... All Astra machines operate with ground coffee and / or pods interchangeably - no ...www.partsguru.com/AstraEspressoMachines.html - 162k - Cached
Sep 15, 2009 | Coffee Makers & Espresso Machines
The rotary table on a No. 10 Blanchard stops turning after about
Does the motor stop or just the table? find this out first, then you can go from there.
Apr 08, 2009 | Saws
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
I have an 10 year old bunn 3g coffee grinder. I was wondering how I could clean and service and adjust the burrs.
You will need a manual that has all the instructions for your machine, as this is too long a subject to answer here. The manual for your machine can be found at: http://www.bunn.com/pages/techdocs/manuals/grind.html
Dec 21, 2008 | Bunn -o-Matic G3 (3 lb. Commercial Coffee...
Grinder setting i
0 is the finest setting. If you read the manual, it advises to adjust your grinder ONLY when the grinder is actually working. Also, you should only adjust it gradually from one setting to the next (ei. from 2 to 3), and wait about 5 cups before adjusting the setting again.
Oct 22, 2007 | Saeco Vienna SuperAutomatica Coffee...
Garden Logo
225 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
