Question about GE Refrigerators
How to level GE Model tfx26ppda bb refriogerator/freezer?
Model tfx26ppda bb side by side refrigerator/freezer
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Posted on Sep 16, 2008
mgprice
  • 744 Answers
SOURCE: Freezer is working but the refrigerator is not.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 10, 2009
Sea Breeze
  • 4654 Answers
SOURCE: model tfh22prsa GE Side-by-side freezer ok refrigerator warm
There are 3 things to look for on the TFH22PRSAAA refrigerator when this happens. First we need to have a look inside the rear of the freezer and see is there is frost build up on the rear back panel that covers the evaporator. If yes you the next thing to do is look inside the fresh food compartment for the defrost timer located behind the control panel as shown in the photo below. I want you to turn the defrost timer clockwise until the compressor motor and fans stop. The refrigerator should be in the defrost mode now. Open the freezer door and listen for crackling and sizzling cause by the defrost heater being on. If there is no sounds or changes the you need to let me know. The timer should turn the refrigerator back on after 25 minutes. If not simply turn the timer again slowly clockwise until the compressor restarts. If you need to do this you will need to replace the defrost timer because the timer is no longer running as a timer and has become defective. I am going to stop here because I don't want you to think this is too hard to do It's easy to do these test and I will be here to assist you. Let me know when you are ready or if you fell you have it under control please rate my solution when were finished the repair, Thanks, Sea Breeze
Posted on Aug 14, 2009
  • 65 Answers
SOURCE: where are the leveling wheels located
The wheels located in the back of the unit cannot be adjusted and the front ones can be accessed under the doors by pulling off the grill assembly. Use the screw going thru the cabinet on each side to adjust the front two wheels. Hope this helps.
Posted on Jan 31, 2010
heatman101
  • 43501 Answers
SOURCE: Hello, i own an GE refrigerator Model No:GDS18SBRALSS
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 09, 2010
My GE model GSH25KGMB BB side by side refrigerator is not cooling on fresh food side. Freezer and ice maker side working fine. How should I troubleshoot this?
On your model I would go straight to the defrost heater and defrost thermostat and check them first after defrosting the evaporator first with a hair drier. Both parts need to be replaced=> WR51X10055 Defrost Heater Assembly 25953576-emtx2i4tcmlh0qfjbwwrn2z1-2-0.jpg and the=> WR50X10068 Defrost Thermostat APPLIANCE 911
Nov 11, 2015 | GE Refrigerators
Side by side refrigerator is hot on the refrigerator side, but the freezer work well.
sounds like the defrost heater is stuck on, will need at least new therm, heater and might need main board
Apr 30, 2012 | GE Refrigerators
I have a GE Profile "Artica" side-by-side refrigerator model PSC23MGNA - BB. Recently the refrigerator door has begun swinging all the way open ... 180 degrees ... and banging into the...
if you look down at the bottom of the freezer door you'll see a door stop,two 5/16 inch screws hold it in place,the stop on the fridge door must of broke.you can switch it from the freezer to the fridge door for now until you get a new one.part number is WR02X13425 and it's around 5 dollars.give your parts store the model number and they will take care of you,or go here,pick any topic here,put your model number in,to the right of the model it will as model or part number,pick model and click on it and your machine will come up,click on fresh food door,your part is numer 12 and you can order it from sears if you want.let me know how you make out
Feb 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Refrigerator model GSS25L GMB BB. The inside shelfs are missing (on the inside of right hand door). Basically, I can only see 16 slots. What do I have to buy for the parts. ...
Take a look here!
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210426&diagram_id=21457731#d21457731
This gives you an exploded view of everything in your fridge.
The freezer section shelving and the fridge side (fresh food)
You can then order what ever you need.
I hope this helps you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 25, 2009 | GE GSS25LGM Side by Side Refrigerator
MY REFRIGERATOR MODEL#GSS20IETA BB DOES NOT GET COLD IN THE REFRIGEATOR SIDE . WHAT COULD THIS BE?
open the freezer and listen for the evaporator fan motor, if you can't hear it running then you need to replace it. it pushes the cold air from the freezer into the fridge to keep it cold.
Nov 13, 2009 | GE Refrigerators
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Model TFX27PFSM BB sise by side refrigerator has de Defrost warning on the diagnostic system but nothing seems wrong with the refrigerator. What could the problem be???? GE Serial # LL209010 purshased in...
If your model is the TFX27PFSM BB I only see a simple defrost timer. But not to say that you possibly have a bad thermistor that came on some models. Part number 305273 This is an alert so I would keep a close eye on freezer and refrigerator temperatures. The defrost thermostat may be defective and the light is warning you of a problem coming. Let me now if I can help you more, Thanks Sea Breeze
Jul 11, 2009 | GE Refrigerators
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
