Question about Linksys Computers & Internet
Linksys SRX400 not working
Router is plugged in, but lights are not on. i tried unplgging and plugging back in, but that did not work
  • Linksys Master
  • 32,281 Answers
The power adapter maybe faulty. Check the power adapter with a multimeter. The voltage reading should be as stated on the label on the adapter, if the voltage is zero or well below the stated voltage the the power adapter is faulty and needs to be replaced.
Posted on Feb 20, 2012
rcsnet
  • 15 Answers
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Posted on Jan 13, 2009
shoran
  • 54 Answers
SOURCE: cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Posted on Jan 15, 2009
kakee
  • 1268 Answers
SOURCE: Blinking power light - router not working properly
Blinking power light on the Linksys routers indicate 2 things. 1st is firmware problem, 2nd is the worst one which is defective router. You can still revive it if you can reload the firmware. If not, it's a dead one and you need to purchase a new one. And man, your router is a very old one. You must switch to wireless G router, its 5 times faster than your wireless B and it only cost 30 or 40 bucks
Posted on May 09, 2009
  • 5 Answers
SOURCE: zhone wireless router 6218 cat5 plug ins'
they shouldnt be "locked" you can try resetting the unit on the back there should be a small button use a paper clip hold the reset down for at least 30 sec while plugged in and try again.
Posted on May 29, 2009
  • 1738 Answers
SOURCE: In trying to install my Linksys router, it shows
Try clearing out your cache, cookies, and temperary Internet folders. Click start run and type cmd and press enter. Then type ipconfig /release wait a little bit and then tyep ipconfig /renew.
Posted on Aug 10, 2009
Linksys WRT300N router flashing all lights
On the back of the router you will see what looks like a pin hole, turn the router on and use a paperclip to push into the hole(it's a reset button) and keep it pushed in till the router cycles off then on again, it resets the router to default. Hope this helps.
Jul 01, 2017 | Linksys WRT Computers & Internet
All green lights on
Try a hard reboot. Unplug it and wait 30 seconds then plug it back in and wait another 30 seconds. This can sometimes solve the problem with routers.
Best of luck
May 25, 2011 | Linksys Wireless-G Broadband Router w/...
Linksys Router G WRT54G v5 Stopped WorkingMy router just stopped working yesterday for no reason that I can discern. I had been using it wirelessly for both my MacBook and my iPod Touch. I noticed that the...
What your experiencing is not uncommon. It happened to me several months ago. I had the same router and did everything you've done without any sucess. I then reinstalled the linksys software and that fixed everything.
Apr 03, 2010 | Computers & Internet
Wrt54gx4 was working and now cannot get a connection between the router and dsl modem. have tried to find new netware but cannot get it to download. Have heard linksys has had a lot of this type of...
A simple solution is to plug your modem in to the lan port of your router. A complex solution is to change your lan ip address different then the modem ip address. For example my lan ip for my modm is 192.168,1,1 and my router is 192.168.9.1.
Nov 20, 2009 | Linksys WRT54GX4 WIRELESS 802.11G...
My Linksys Router has been working fine for 3 years. Suddenly, it stopped working and the Security LED is stuck at Orange and Internet LED doesn't light up. Is it a problem with the Line ?
Router can be misconfigured.
Try to reset to default.
Shutdown your computers.
On the back out the router there is a hole which you can insert a paperclip, toothpick etc, hold it for about 5 seconds then pull out the power plug.
After about 5 seconds plug it back in.
When the lights stabilize boot the computer.
Try to access to default ip: http://192.168.1.1 or http://192.168.1.101
username:admin
password:admin
Oct 20, 2009 | Linksys (NR041) Router
Hi there I no longer have the AC power adapter for my SRX400 router. What should I buy as a replacement? I've tried a few around the house and none work. I've searched to see if I could find the specs (the...
Contact the Linksys customer care and ask for a power adapter. Don't tell them that you have lost the adapter. Just let them know that the adapter no longer works. Now here's the catch. You must first call up the technical support; prove to them that the adapter is bad; and obtain a case id. Once you are done, follow the following link and choose the third option - "Ship only RMA request"
https://linksysrma.moduslink.com/Consumer/pag/Homepage.aspx?country=US
Note: The mentioned link will only work for customer in US.
regards
Sandeep
Oct 13, 2009 | Linksys WRT54GX4 WIRELESS 802.11G...
My linksys wrt54g was working fine. WE moved my computer and it stopped working. I reinstalled the driver and when it came to the point of trying to recognize if the router was connected it could not find...
The lights on your router indicate a firmware problem. To fix it, you need to hard reset the router. Press the reset button at the back of the router for 30 seconds then unplug the power. Wait for a minute before you plug it back in. Check the lights again. That should fix it.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Problem with a linksys ethernet cable router
The router may need to be reconfigure since you lost the internet connection , If you still have the setup CD you can just run it again or better call Linksys Tech support so they can walk you through with the process the number is 800-3267114 you can call them any time of the day..
Hope that helps.......
Sep 03, 2008 | Linksys WRT54GX4 WIRELESS 802.11G...
LINKSYS WIRELESS - G WAG54GS
Diana, The router has lost its IP address from the ADSL gateway. Unplug the router from the wall for about a minute or two. Plug it back in..? If that doesn't work you need to login to your router and check the settings. or(there is a small reset button on the back of the router. Hold it in for 10 seconds the router will reset.) http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper If possible turn your computers off while resetting the connection. Some inter Microsoft networks will issue its own IP if it doesn't detect one. Good Luck, Tim
Feb 07, 2007 | Linksys Wireless-G WRTP54G Router
Computers & Internet Logo
134 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
