Question about Sony RDR-VX515 DVD Recorder/VCR
Can't read un-finalized dvd disks.......
Hi!
i was finalizing a dvd in my sony dvd recorder.
the power went off in the middle of the finalization process.
now the dvd disk can be read on my handheld vd recorder, but not by my dvd player hooked to the tv.
this brand of media has worked fine in this sony dvd recorder before so i doubt it is the recorder or the media.
also, the movie is there on the removable dvd disk , because it plays fine when in the handheld recorder.
what about the pc of software from cdroller.com that appears to be able to resolve this type of issue, a 'non-finalized properly' dvd disk?
thanks for any ideas/suggestions/resolutions !
mark newhall
markred33@yahoo.com
4 Suggested Answers
SOURCE: Toshiba d-r4su won't finalize
Also if you use 16X media you need to contact Toshiba to get a firmware disc.  This has been known to happen to me a lot before I had a firmware upgrade.  The unit can record to 16X but not finalize.  I have always used Memorex media.
Posted on Oct 29, 2007
SOURCE: DVD -R finalizing
using a dvd+r with 1-16x speed is not advisable for this recorder. It may work but in the long run may cause some trouble. check the manual for compatible disc. it will give you hints on what disc to buy and use. Unfortunately this unit is only compatible with dvd+r dvd-r that are 8x speed or slower. hope this helps.
Posted on Mar 14, 2008
SOURCE: unit cant recoginze/ read a disk
I have a pioneer dvd recorderDVR-310-S which recorded a lot of movies some movies were not finalized.the machine will not read any of movies Problem--- trouble getting the machine looked at.
have since purchased a Panasonic DMR-EX79 it also will not read the unfinalized movies
Posted on Jan 21, 2010
I have a jvc dr-mv150bj. I am knew to recording on DVD. I used the dvd to record the super bowl. I forgot to finalize and I was using a portable LCD projector. I unpluged the dvd recorder and took it...
finalizing completes the process of recording so that the disk can be read to play. Yes, probably if power goes off, you'll loose the recording as the disk can finish.
Basically, the code written at the end of recording creates a sort of index so the player knows how to read it.
May 02, 2017 | JVC DR-MV150B DVD Recorder/VCR
I have had my sony rdr-gx257 dvd recorder for about a year now, never been used. I have been recording gameplay from my ps3 with it since yesterday. I have recorded onto dvd-r disk and dvd+r disk however...
After ending recording, Finalize recorded dvd as option is available in recorder menu.
a Finalized dvd will playback in other dvd players.
Thanks.
Dec 30, 2010 | Sony RDR-GX257 Player
Can not finalize disk
I have had loads of people ask me this question in just 2 weeks, so it often does happen okay?
Anyway you should not have to do a finalize on the disk, because when you stop filming, the camera reads it's end bit to the DVD auto, then after a few seconds you should be able to open the camera door.
May 29, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Unit cant recoginze/ read a disk
Randy,
I had a dvd-r disc recorded from a Philips dvd recorder that had not yet been finalized when the Philips went bezerk and died. I replaced it with the Sony GX300 and just for an experiment, tried to finalize it in the Sony
It worked. Not to say that it has to work with only THIS combination of the 2 same dvd recorders or twisting the scenario around with the Sony doing the recording and the Philips doing the finalizing. I also have a Sony dvd/vcr recorder to compliment the GX300. I will have to record a disc on the GX300 and try to finalize it with the combo unit to see if it will do well as a back up.
Right now a disc that is not full yet (home movie from my kids birth) is reading "Disc Error" on the GX300. I may have to do it over or see if the combo unit will do the same finalizing as the GX300. It doesn't have the amount of features that the GX300 has but thats what you get with a combo unit vs. a stand alone recorder/player.
If you know someone with another recorder, try to finalize on it. If not , you could find someone on this sight that has a GX300 and mail the discs plus a smalll fee and have them mailed back. Or you could find a used one cheap at some store and return it if it doesn't finalize.
Good luck
Dave
azsnoopy1@cox.net
Dec 28, 2009 | Sony RDR-GX300 DVD Recorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Either my computer or dvd does not read movies recorded by this camcorder. Why?
hi. in many DVD camcorders. you are suposed to closed o finalize the dvd disk . by doing this it will be playback compatible with your pc or dvd player.
NOTE
after finalizing a disk you will not able to record any longer on that disk (DVD-R, DVD+R, DVD-RAM, DVD RW) If you record for 5 minutes and finalized the dvd it will have a 5 min movie !!!
Oct 08, 2009 | Canon DC20 DVD Camcorder
What other DVD recorders will finalize my Insignia DVD's?
i had same problem, the laser is going bad. soon it will not read any disks.
and had many disks not finalized. so i bought a new one (jvc) and it does read the other disks not finalized. hope this helps
Jan 14, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Recorded DVD wont play on any other DVD Player
I lost my manual. Can you describe how to finalize it? I can't finad any buttons to press that say finalize on them.
Jun 01, 2008 | Funai TruTech DVDVCR Dual Recorder
Finalize Error
You can not retrive unfinalised disk because no path was put into place to read the information that was burnt. Data yeap was burnt but way of reading it was put into place.
Mar 25, 2008 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Can not read the disc if recorder is disconected before finish finalize
what do you mean the power went out if it did while the disc was burning then the disc is now a coaster (no good)
Feb 06, 2008 | Sony RDR-GX315 DVD Recorder
Sony RDR-VX515 DVD Recorder/VCR Logo
505 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
