Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Freezer side works but fridge want get cool
On a side by side the freezer side works but the frige side will not get cold
  • 19 Answers
SOURCE: Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Posted on Nov 06, 2007
  • 833 Answers
SOURCE: Frigidaire Fridge PLHS69EESS2
Could be a jammed fan or something could have moved inside to block the opening. Some units have deflectors in the openings...did one of those cover the opening on the fridge side? Did you overpack your freezer and block the air flow from there to the fridge?
Posted on Jan 03, 2008
SOURCE: The freezer works very well but the refrigerator is not cool enough
check if fan in freezer is running , stryo is air diverter leave alone. ck frz temp rkm
Posted on Jul 11, 2008
farfield
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
joecoolvette
  • 5660 Answers
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Posted on Jul 05, 2009
It is not cooling as well as it does usually. The freezer is cooling at frige temperture and the frige side is hardly cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
heatman101
Apr 25, 2011 | Refrigerators
Freezer workes but frige side not that cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | LG LSC27931S Side by Side Refrigerator
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frige problem
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Aug 13, 2007 | Maytag MZD2768G Side by Side Refrigerator
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
