Question about Hamilton Beach GE Coffee Grinder, Model No. 106854
Ge coffe grinder one touch model 106854
Hi
I started grinding some almonds and one got stuck in the blades and it stopped working and it has a smell of burnt windings..how do I open the little buger to see the insides?
please help
is there a repair manual somewhere I can download
Unfortunately you cannot solve this problem. Everything inside in not serviceable. The grinder is strictly a use and throw away unit. I would suggest keeping the plastic cap though if it is in good condition. I have owned 3 and all of them have had to be replaced just because the cap cracked. Both GE and Hamilton Beach make the same grinder. Start your search there. They are on ebay for around 20 bucks. Hope this helped.
Posted on Jan 29, 2009
  • nightbreed99 Jan 29, 2009
    Also you can find one here at Wal Mart.
    http://www.walmart.com/catalog/product.g...
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
DCC-790 Cuisinart coffe maker won't grind
what showing on display ,when push to make coffee? If showing grinder block-then you have to replace the grinder to fix it. Try to grind coffee ,but without beans-if grinder start but rotate slowly -you have to replace grinder and change the brushes of the motor.
Oct 04, 2013 | Saeco Royal Professional Espresso Machine
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Not fine enough grind
This model grinder won't do espresso. There is a DIY mod available online that involves disassembling the machine, and recalibrating the burrs to produce a finer grind. I did it on mine, it was definitely better, but it's not going to get you to the coveted 30 second pull for your espresso. Search on Starbucks Barista Grinder Mod. It is a great grinder otherwise, very reliable.
Jan 09, 2010 | Solis Maestro Electric Burr Grinder
I disassembled the grinding blades and put it back together but now I can not get a find grind
HI
When you reassemble the removable burr assembly, you first must make sure that there are no grinds left in the main body's threads. These grinds will prevent the burrs from going any farther down. The burrs must touch and then back off to zero the grinder. Don't ever leave them touching though.
Nov 07, 2009 | Rancilio Rocky SD Grinder without Doser -...
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Stopped working
Not to worry. This grinder can be filled till the top. This will be covered under warranty. Just give a call to Cuisinart and they will fix it for you
Feb 23, 2008 | Cuisinart SS Grind Central, removable bowl...
Coffee Makers & Espresso Machines Logo
653 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
jason
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
