Question about Conair Weight Watchers® WW78 by Glass Body Fat Scale Black Chrome
My WW78 scale keeps giving an ERR message when I stand on it.
It weighs up to maybe 25 lbs, but after that gives an ERR. I've tried replacing the battery but it hasn't worked. any ideas?
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
Posted on Oct 24, 2012
4 Suggested Answers
SOURCE: Conair #WW78 scale doesn't reweigh
;i have a problem with the conair ww78. It does not reweigh. It shows the same weight each and every day. What is the problem and how can it be fixed?
Posted on Mar 22, 2010
  • 10865 Answers
SOURCE: My weight watchers scale keep giving me the
Change the batteries. J.
Posted on Jun 15, 2010
r321567499
  • 74 Answers
SOURCE: ERR comes up when standing on scale?
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
Why do I just get an ERR message when I try to weigh myself?
The replacement batteries could be of the wrong type, defective, or incorrectly installed.
Oct 02, 2015 | Conair WW60 Weightwatchers Scale
Reset for lbs
Usual to have a switch underneath the unit , lbs or kllos
Mine 6 years old & has this switch.
Mar 13, 2015 | Conair Weight Watchers WW78
UP TO HOW MANY POUNDS CAN BE MEASURE IN THIS SCALE
I don't know specifically for this model, but for most like this, 300 or 330lbs is typical. To test a working scale for its max capacity, let a heavier friend try it or carefully hold a weight in each hand and stand very still when its a digital scale. A gallon plastic milk container weighs about 9lbs, so one in each hand,even if filled with water will give you an extra 18 lbs of testing room. You can also let the heavier friend or other person hold the weights to help you test the upper limits.
Jun 07, 2013 | Health-O-Meter Health o Meter BFM681DQ-63...
ERr
Are you talking 31 "Stone"? If so, I believe that comes out to 434lbs. You are lucky if your scales can read that high. For testing purposes, remove your shoes or more if you think your right at the upper limit. Or let a slightly lighter friend try it. I assume your talking "Stone" as used in the UK. Are you from there? (I,m in the US, in Florida.) Also, there should be a switch on the bottom of the scale (upper left corner) allowing you to switch between lbs, st and kg. You can try that as well, although the limit should be basically identical. If you tell me more, I can help you more.
(By the way, I weigh 197 lbs right now, that's 14 stone.)
May 19, 2013 | Health & Beauty
Display gives Error message
On my scales you have to have bare feet for it to measure body fat index, if you still get err, moisten ythe soles of your feet with a cloth to get a better contact.
Jan 28, 2010 | Tanita Digital Body Fat Scale with 2...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Conair Weight Watchers® WW78 by  Glass Body Fat Scale Black  Chrome Logo
1,858 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
