Question about Servis 23 in. M4308 Free-standing Dishwasher
Servis Quartz M9130 Washing Machine Problem
I have a 5 year old Servis quartz M9130 which has stopped turning at all with a full load, and which turns in only one direction when there's anything more than a very light load in. I've had the back off, and there's nothing wrong with the belt. With a light load, the motor can just about turn the drum clockwise, but can't manage it anticlockwise and just 'strains' instead. Is this just an old, tired motor, or should I be cleaning certain bits of it to help it along?
  • Anonymous Nov 20, 2007
    same
Try changing the brushes in the motor...
Posted on Jul 10, 2007
I have Relic VX3J 3 Eye - stopped working after 2 years.
If turning the adjustment bead does not result in a clicking then it is likely quartz. I am presuming it did not require winding. So if it clicks and comes back to life it is automatic (just wear it to charge it) if not then it is likely quartz. Most automatic watches can also be manually wound to charge. This is better for the movement when it is fully unwound, 10 full turns to be on the cautious side from flat. It is unlikely you can overwind good quality modern watches as they have a clutch to prevent over winding. cheaper watches may or may not have this feature.
Mar 22, 2014 | Relic Watches
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
Jan 13, 2014 | Westclox 47550 Quartz Loud Bell Analog...
Eleven year old Whirlpool electric dryer cannot turn the drum with a full load of towels. The motor turns on but then shuts off. It will turn a very light load.
Turn the drum by hand. It should rotate fairly easy in one direction. If so, then the motor is going out and need replacement. Fairly common problem.
Jul 13, 2009 | Estate TGDS840JQ Gas Dryer
Servis washer fault
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 07, 2009 | Washing Machines
Servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Mar 18, 2009 | Washing Machines
Servis fridge / frezer not colling or freezing
i would firstly do a complete defrost- incase there has been a fault with the frost free system. if after a full defrost it runs ok then there was a fault somewhere in the defrost system including either defrost heater, cut out or possible jammed circulation fan.
Feb 05, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Dec 14, 2008 | GE WPXH214A Front Load Washer
Noisy Servis M9503S
Hi.
Remve the belt, and turn the drum by hand, if it sounds rough or is noisy, then yes the main drum bearings have failed.
It is a DIY job , but can be expensive, probably cheaper to buy new washer if it is more than 3 or 4 years old.
Nov 22, 2008 | Hoover AAA140 Front Load Washer
Hi there, I have had my Servis M9813W for 2 years now, the other day i went to do some washing and the door would not lock - tried slamming it, turning off the machine but no avail - it will not lock and...
Unplug it, wait 2 minutes and try again.
Otherwise
5 year parts guarantee, 12 months labour. All Servis appliances come with a full 12 month parts and labour guarantee and an additional 4 year parts warranty (to take advantage of the additional 4 year parts warranty, the guarantee card must be returned to us for registration) which reflects the confidence in our range of products.
All products are extremely reliable and we hope that this guarantee demonstrates that Servis are serious about providing top quality products to the marketplace.
The after-sales service is provided by our own national team of service engineers who are fully trained and only use Servis replacement parts guaranteeing the long life and performance of your Servis product. Contacts Servis Cares Call Centre: 08705 168299 Proactive Repairs: 0121 568 2270 E-mail: proactive.repairs@servisuk.co.uk Replacement Parts: 08705 168299 E-mail: spare.parts@servisuk.co.uk
Sep 16, 2008 | Washing Machines
Squelling noise
Check the water pump. Remove the belt and turn the pump by hand in both directions. If there is a problem you will feel the pump try to grab. A lot of times some small objects that get in the washer and end up in the pump and causes everything from clicking noises to full stop.
Dec 03, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Servis 23 in. M4308 Free-standing Dishwasher Logo
466 people viewed this question
Top Servis Dishwashers Experts
Gil Davis
Eric Taylor
Day Coker
Are you a Servis Dishwasher Expert? Answer questions, earn points and help others
